Removing Rear Bumper with Parking Sensors
Okay this might be a long show but has anyone with factory parking sensors removed their rear bumper? Is it just a few connectors I have to unplug or it is alot harder? I just want to put some type-s tails in.
94 DC4 RS LSV/Turbo
you wont have to remove the full bumper to install tails, you just have to drop the sides, the harness is long enough to allow for you to do this, or you can unplug the harness located behind the tails/inside the trunk liner, you will see it when you are in there, good luck
Not sure about the tails,
I just installed the rear bumper sensors. You will have some slack, however if the sensors were installed properly, you will have all weather tape placed around the connector and it will be a pain to remove and get to the connector. You should have about six inches of slack with the bumper loose.
Randy B
Randy B
mada51589
05-03-2022 08:54 PM
obsessedmotors
09-10-2015 10:49 AM
09-04-2015 08:03 AM
