Rear vents not working
Has anybody had problems with their rear vents (the ones behind the center console)? With the heat on, I can't feel any air blowing from them. The dealer said the air flow would be light. Just wanted to see if anyone could save me a trip to the dealer.
2004 NBP
2004 NBP
When the heater is on and the A/C is set to Auto, the air flow is directed downward, so you will not feel much air coming out of either the front vents or the rear vents. There is a duct under each seat which carries the heater air to the rear of the car.
If you want air to come out of the vents behind the arm rest, you will have to use the Mode button to change the setting manually.
Originally Posted by vtechbrain
In this case, the answer could not be obtained by since there is nothing in the manual which exactly describes the condition being asked about.
It does not say that when you put the A/C on in AUTO mode, which is what most of us do, that the air will be directed downwards if the temperature selected is higher than the current temperature in the vehicle. This would cause a person who is accustomed to the air coming from certain vents when cooling was called for to wonder why the air was not coming from those vents when heating was called for and the A/C was still in auto mode.
If the answer is provided in the manual, it is written in such an obtuse manner that the average person would have trouble deducing that it was actually the answer to his problem.
mada51589
05-03-2022 08:54 PM
