Rear sway bar - oem or progress?
2021 RDX A SPEC
Did an inspection during tire rotation and the oem rear sway bar is all cracked up on both sides. Not looking good. Best options?
I did a search and it's all about comptech vs progress.
Hows pricing and is it DIY-able? anyone got a link to purchase from?
Also how unsafe are these cracks?
Jeebus.. i'd replace them and the sway bar links soon...
Do you have a base or Type S? A type S bar on a base TL provides a slight performance bump and is cheaper than a Progress bar. Definitely DIY-able. It's 4 bolts for the 2 sway bar anchor points and then 1 bolt on each side that connects to the sway bar end link.
Not so shameless plug: I do have a Type S bar brand new that I'd be happy to sell if you open up a FS thread on the Black Market.
2021 RDX A SPEC
so then, the question you have to ask yourself is...
Would you like a stiffer bar? or were/are you happy with the stock bar?
if you are happy with the stock bar, then pay the $50 or so(hope it hasnt increased with time) and replace the stock bar.
If you would like a STIFFER bar, then upgrade to the Progress bar.
If you dont know, then you are most likely happy with the stock bar.
CAD Guy
I can almost guarantee the cracks you are seeing are in the coating on the sway bar, not the actual bar itself. The coating they use on sway bars, suspension springs typically crack just like that on every car, including aftermarket components. You also need to remember that the sway bar is constantly being flexed, twisted, etc...while driving, they actually sell a DIY coating that is meant for stuff like this if you wanted to re-coat it.
Every car I have owned in the rust belt has had sway bars look just like it, my TL is starting to do this as well, since its my only car I have had to drive it year around, unlike the previous owners. If you want to replace it, just grap an oem one, they are relatively cheap and fairly straight forward to replace.
2021 RDX A SPEC
^^^ thanks..yah..the coating was very brittle... i was tempted to just remove it.
in any case, let me consider a replacement - it doesn't appear to be mission critical stuff?
Rear 20mm
93402-08016-08 BOLT-WASHER (8X16) 4 needed
52306-SEP-A11 BUSH, RR. STABILIZER HOLDER (20MM) 2 needed
52308-S3M-A00 HOLDER 2 needed
52300-SEP-A11 SPRING, RR. STABILIZER 1 needed
Rear 20mm
buy a stock bar from a crashed TL for $20
www.oemacuraparts.com type in your car model and year and then go to rear lower arms, like so: https://www.oemacuraparts.com/v-2008...rear-lower-arm
then you can find all the parts and use that part number to look for it elsewhere..
2021 RDX A SPEC
thanks!
just to confirm, end links i would need are:
52325-SDA-A01
52320-SDA-A01 -- i see another part number for this but assume this one replaces it (52320-SFY-J01)
52325-SDA-A01
YUP looks correct.
HEAVY_RL
24
09-20-2013 08:24 PM
