Rear Antenna
The antenna module unit (#8) is mounted on the left C pillar. It may be behind the C-pillar cover. I believe, the radio signal is amplified (behind passenger kick panel -- #11) before fed to the radio.
So I think, it's still easier to remove the radio/center console than working on the antenna directly. Besides, the plugs/connectors will not match your FM Modulator.
Registered User
That B-13-40 77962 is behind the dash. He doesn't want to take the dash apart....
What I meant by "Besides, the plugs/connectors will not match your FM Modulator." is the plugs on the antenna amplifier or antenna module won't match his FM Modulator.
Acura TL2k4: Based on the image, the antenna module should be behind the C-pillar cover.
Now with i-Vtec
Originally Posted by rbf351
you are incoorrect about the plugs being different, you can use the plug that goes into that box, if you look at the picture it is B-13-40 77962(standard car antenna plug)
~Chris
BoricuaTL
04-08-2016 01:08 PM
oyayjoe
09-12-2015 04:40 PM
