Rattles located and fix's. LOOK
HEY everyone .. I always felt like since its been getting colder that its a war or battle with my car and its rattles. So I decided I wuldnt stop tll I found the most complained about ones...
1. Sub Rattle-
-Open trunk, take off the upper felt lining. You will see a bunch of circles and oval shapes. There should be a small circle, one in the middle somewere look for it and while your playing music press up into it. It will stop. Stuff sum dynamat or foam padding in there no more rattle .. also you might have the rattle still, but not as loud. Look deeper in the trunk more you will see the seatbelt harness that also rattles I have no fix for this yet, but if you go to you're dealer make them do a better job on tightening it and I think you'll have that rattle fixed.
2. Under nav rattle-
-Can be solved by leaving trays open but if you put a foam insulation in between it stops .. also the one by the cup holders and shifter. None thought it culd but its the e-brake button. Hold it right or left tightly and it stops. Also silicon spray every crack by the shiftplate and cracks all over the car. Rattles vanish just be careful around instrument cluster..
3. Under foot by pedals rattle-
- Its the top plate that holds the wires from hitting your leg or your leg for hittin the wires .. whatever . foam insulate that so when it hits its soft..
4. Door rattles-
Its the sunglass holders glue /tape/ foam insulate/ dynamat;;; do sumtin that isnt messy that holds it in one place when finished silicon spray ..
5. Seatbelt rattles-
If you tap around see if its the actual harness or the plastic surrounding it. Either way foam insulate one spot of it so that it doesnt bounce anymore and walaa
6. Another trunk rattle-
-Open trunk take the felt lining off the trunk itself and you will see a wire. Wrap it up in foam or sumthin soft. Its whenever the bass hits it, it hits the metal and makes a buzzing rattle.
7. Another bass rattle buzz in the back
The freakin rear brake light inside the car .. this is hard plastic that rattles against the window. this is fixed by foam insulate or get the clear silicone glue that dries like gel and apply with a q tip in one spot like a dot in the middle
1. Sub Rattle-
4. Door rattles-
Gratis dictum
Originally Posted by jmn4667
Boy, this one sure is difficult to read. Can a Mod clean up the grammar a bit?
Corey_Straker (09-19-2014)
"...Nice post regardless. Children or not, shouldn't everyone be encourged to contribute if they think they can? I think so. Good post..."
I agree with Akim. At least it is a valid and constructive submission. It beats the hell out of some of the crap that gets posted here.
Gratis dictum
Bucky O and akim...............I agree completely with you guys. I don't have any problem with the content of the post and I would encourage anyone to make their views known. All I am saying is that if some folks would sharpen their communication skills it would be helpful to readers.
2004 TL w/ 6MT & Navi
Gees, chill out!
Moderator Alumnus
ravingstylez, thank you so much for the details. It's good to see someones sharing this info to all of us. Even though most of them are well-known issues/fixes, we're pleased to know that Acura dealers find ways to fix them now.
Originally Posted by rets
Well said.
CEO, Team Anthracite
Originally Posted by ravingstylez
3. under foot by pedals rattle-
- its the top plate that holds the wires from hitti your leg or yoru leg for hittin the wires .. watever . foam insulate that so when it hits its soft..
Not our policy
We don't like to change people's posting unless they ask us to or unless they are in violation of the rules.
It's better to struggle through a unique form of communication than to mess with someone's original expression of ideas, IMHO.
Want to borrow my Rosetta Stone?
Thanks anyway. :rippedoff
watever guys i can read it and undertstand it perfectly must be a staten island high school kid language because ebryone i tlk to can understand it also
when i have more time i will reiterate it in proper english ..
BlkTxAcuraTypeS
10-18-2015 08:05 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
