Radio fuse doesn't affect HandsFree Link!
Hello again.
Still having that problem with a frozen HandsFree Link in "In Use" mode which keeps the radio off. Someone mentioned to pull the fuse for the radio thinking it would power down the HFL as well. It does not. I couldn't figure out which fuse is connected to the navigation system either. Does anyone know? Some of the fuses are labeled with abbreviations that are not elaborated on. Thanks.
-Josh
-Josh
Re: Radio fuse doesn't affect HandsFree Link!
Originally posted by jayelwin
Hello again.
-Josh
Hello again.
-Josh
Hello again.
Hello again.
Something else you might try is having someone call your cell phone while it is in the car with the HFL powered up. The one time my HFL "glitched" and thought the phone was "IN USE" when it really wasn't, an incoming call seemed to kick things loose again.
I wonder if there is a reset switch hidden somewhere in the back of the HFL unit? Anyone ever take the unit out of the headliner and check?
visiter555
04-09-2016 12:56 PM
