Radiator Cap, where can I get it?
05 TL
I've been spending too much time in /b/ (other web site) and I wanted to provide a smart ass answer, but since this is a good forum I'll give you the correct answer
acuraOEMparts.com
19102-PM5-A00 CAP, RESERVE TANK 1 2005 TL (1.42 LIST) 1.14
acuraOEMparts.com
I would blast you for that but since this is a good forum i'm going to say thanks for the part (and the site)
Hmm, I wonder if I can just pick the part up at a local dealer? With the holidays fast approaching, It will take like... forever for the part to come in! I'll call tomorrow. The part itself is cheap but I'm sure the dealer will mark it up.
I got the actual radiator cap for my 3G once at a honda dealer (closer to my house) - same part - the honda parts guy just called an acura dealer to ck the part #
As long as the tubing isn't cracked shoudn't be loosing any coolant through the top of the reservoir. As you can see the MAX line is quite a bit lower than the cap. Place some talcum powder around the top of the reservoir and then you'll be able to see if any is leaking out as the powder will highlight the moisture. If none, have the system pressure tested when cold, but cetainly can't hurt to replace the defective part.
Our TL coolant level drops ever so slowly, but just been too lazy to throw the tester on the system. Come spring maybe it will be a good time to do the test along with a coolant change.
I have shitty luck...
I went to the dealer and was able to get the top for under 4 dollars, Sweet!! On my way home on the FDR, this city truck had something that fell off his truck and smacked my lower left portion of my front bumper causing the paint to crack in more places than 1...F*&K. I followed the guy and took pictures getting his license plate. I'll file a report with the City when the holidays are over. an a spec front lip might cover it.
