Question for those with halo's in your headlights
What bulbs are you using in your DRLs to match the color of the halo rings? What bulbs/LEDs are you using in your side markers to also match the DRLs and Halos?
I'm planning on eventually having JnC do my headlights (including Halo rings) but want to make sure all the colors in the headlights are as close to each other as possible. Thanks. |
I took out my DRLs so I dont have to worry about it... Where in Jersey you from?
Originally Posted by sunny201
(Post 10914332)
I'm in Northern NJ, currently Weehawken... soon to be in the Nutley / Belleville area (hopefully). Anyone else want to share their setups? |
Originally Posted by NJDEE
(Post 10917275)
That thought came to mind actually... simple as unplugging the bulb, correct?
i have no DRL but instead 3000k yellow fogs in there =)
oh and no parking lights either. they only blink with blinkers |
Originally Posted by GTkim83
(Post 10920209)
oh and no parking lights either. they only blink with blinkers Curious as to how to rigged you parking lights to blink only and not go on when you turn your parking lights on. |
(Post 10920120)
Ohh.. Im in Lyndhurst all the time
(Post 10920256)
As you see in the picture below of a 1157 bulb, the shot to the right, there are 2 contacts at the bottom, just cover one with electrical tape and test. If the parking light turns on, then move the tape to the other one. Voila!
http://www.made-in-china.com/image/2...p-1157-24-.jpg |
There are three wires on the 04 TL parking bulb. The one wire in the center is the Parking light. Cut it and cap it, or use mglax's tape method. Done and done.
MY question is how are you getting the foglights to come on without the main headlights?? |
