Question on SS
Question on SS
Is there a safe guard when using SS that will prevent you from over revving..i.e Stop you from going into 1st gear when doing 70+MPH? Just curious?
Shift_faster
Originally Posted by cTLgo
I know it prevents me from doing so on my MT so I don't see why the AT wouldn't be the same
The AT will NOT allow you to downshift to a gear too low to handle the rpms. It is designed that way.
Originally Posted by PoochaKannInc
I think a dedicated idiot can get it into gear, and if they were ignoring all the signs the car was giving them, they could engage the clutch and watch their engine explode.
The computer has many safeguards built in to prevent harm to the engine. It will not downshift to 2nd gear at speeds over 60mph and rpm's over 4,000. It will not let you downshift into any gear if the engine rpm's will exceed the limit, and, as stated, 2nd gear is even more carefully guarded.
There is a rev limiter which will cut the engine on and off when you reach the rev limit of 6,800 rpm in any gear.
Shift_faster
Originally Posted by cpurick
Nah. This is beyond the capability of the synchronizers. You'd grind them down to nothing in just a second. Then, the next time you pulled up to a light, you'd discover you couldn't get it into first anymore.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
