Question: Removing Front Grill Trim without Removing Bumper??
So I recently picked up a Type-S spoiler which I need to get paint matched to my anthracite metallic and thought, why not get the silver trim on the front grill as well as above the license painted while at the body shop (I’ve always wanted paint matched trim anyway and getting it done simultaneously will be cheaper).
Specifically, I’m questioning the horizontal bar which holds the “A” emblem and the V shaped lower molding. Is it possible to remove these pieces without removing the front bumper??
Here are both of the scans for this removal:
http://img.photobucket.com/albums/v2...repl20-129.jpg
http://img.photobucket.com/albums/v2...plpg20-130.jpg
Yes, I know the first line states “remove front bumper,” but I have been told this step can be avoided.
I’ve taken a look into my grill and I'm not seeing how I can remove these trim pieces w/o taking the bumper off. When I remove the front shrouding under my hood and look down into the back of the grill I can access the two screws behind the "A" but the other four screws appear to be in front of the "front grill cover" (marked as letter A on the "Front Grille Replacement" section of the manual 20-129) which is blocking them. There appears to be raised square sections w/ little circles etched on the front grill cover where I believe the screws are behind. (I hope everyone is still with me lol). Can anyone enlighten me?
Also, I don't see how I can remove the "front grille lower molding" on 20-130 with my bumper on because I supposedly need to use a screw driver to pry the tabs out along the entire piece.
I'd really like to avoid taking off my bumper b/c I'm getting these pieces painted meaning my bumper will be on and off a few times between taking the stuff to the shop and eventually installing them (not to mention I’ve taken the bumper off/on before to install JnC headlights and I don’t want to loosen anything up from the constant removal).
Also how does everyone feel with my decision to get the three trim pieces on the front painted? I’m asking b/c I see many people that just paint match the V shaped lower molding and the trim along the hood, and instead paint the horizontal piece black (along with the “front grill cover” [black plastic piece behind for those not listening ]). I don’t plan on touching the black areas of the grill, and would like to leave them as is. It will match the lower grill slots this way.
And if anyone is curious, I was quoted at $70 to get the Type-S spoiler painted, and $120 to get the spoiler along with the four trim pieces painted (horizontal “A” bar, V shaped lower molding, trim along front of hood, trim above license plate). Good prices?
Any help would be greatly appreciated!!! Thanks guys (and girls).
see my post from this thread here Post #12
https://acurazine.com/forums/3g-tl-2004-2008-93/driving-without-grille-744726/
https://acurazine.com/forums/showthread.php?t=744726
Also, you just pulled out the lower trim piece (item 4) with no problem? When I tried starting at an end it felt like it was going to snap to me.
Taking off the front bumper takes literally 3-5 minutes. I don't think their is an easy way to access those screws to remove the grill while the bumper is in tact. Instead of risking something getting broken by tugging on clipped stuff, just make it easy on yourself and take the bumper off?
TimTim and powerflow:
I hear you guys, and yes, taking the bumper off seems like a no brainer. However, my reasoning behind avoiding this step is, the more you take things apart, loosening and retightening, the higher risk you have at it not fitting snug back together the same way potentially resulting in unwanted vibrations, etc. I know there isn't much too the bumper (I've taken it off before) but I'll have to take it off to get the trim off, put it on for the interim time period while the pieces are in the shop, take it off again, then finially re-install. Sort of a pain with the winter coming up and as we all know plastic does become brittle in cold weather.
Anyway if it can't easily be done with the bumper on, than I might not have a choice but to take it off. But if anyone could share their secrets or help me with my above posts (specifically #3) I'd be really appreciative!!
Thanks all on your comments so far.
Off roading in his
I ended up removing the bumper, taking off the grill, putting the bumper back on. Drove without the grill pieces for a few days and removed bumper again, installed the grill and the car is as good as from the factory...keep in mind I was a total NEWB when it comes to removing the bumper, I'm slightly more experienced now.
https://acurazine.com/forums/showthr...t+bumper+aspec
or
or
I'm sure there is plenty of other good info on this topic in the 3G garage as well. But next time spare yourself and SEARCH
I was faced with the same dilemma when removing my grill to get it overlayed. The way to take off the grill without taking of the bumper opens up to higher chance of damaging things. The screws behind the horizontal bar are very hard to get to and if you try to pull the V-shaped trim from the front, you risk scratching it and it getting bent out of shape.
Hmm...now I just have to find the time to get it all done!
mrlobaloba:
I'm still curious to hear your responce to my follow-up post (#3)...
And sorry to talk in circles, but ZhenyaF, do you know of the little raised "boxes" I refer to on the black grill section? How can I even get to these four screws bc I can't find them! lol
I also have smaller hands & forearms which make it easier . I remove the "A" a lot cuz I swap from chrome to painted.
As for items # 4 & 11 .. dunno .. never removed them.
In #3 if your refering to the cross bar that has the "A" attaced to it I remove mine all the time without removing the bumper ( 6 screwes #10 ) . I have a miniature ratchet that holds the hex screwdriver bits and I can access the screws after I remove the plastic cover over the rad. Some I get from the top .. some the bottom. Once I have them out the first time I swirced them out to Robertson head screws which make it a lot easier. The screws are hard to feel because they are recessed a bit in the cross bar.
Yeep ... also if you have one of those mirrors with an extention handle .. use it and a flashlight to see in general where the screw(s) are then its easier ... first time was a bit of a struggle and a tight squeeze.
Off roading in his
Thanks for your advice ZhenyaF. It's looking like I'm going to have to take this route I guess. Even though there is a way to get the center piece and V trim off, like you and others said it's at the expense of scrathcing/bending/breaking those pieces.
mrlobaloba:
mrlobaloba:
The A-Spec lip comes off with the bumper together as one, peice of cake.
Definately take the bumper off. When I did my grills, I ended taking my bumper off a few times, to redo them. The thing I ended up doing was to put in only the necessary bolts/clips/screws just to hold the bumper in its spots. Its held in pretty well with the clips anyways. I ended up with a handfull of plastic clips. Took me about a 2 minutes to take it back off again when I was ready, I spent more time turning the weel to gain access to the fender well than taking the bumper off.
I believe the center clip is only there for manufacturing purposes, when they assemble the car in the factory.
anyone else have any advice for how to take this off? im afraid when i pull the part that i might crack the grille trim in half.
there should be some way you can get teh clip out. the manual says you can get it out of the hole, but i havnt even found it yet
i just figured out how to do it
if you go from the little part that locks the grill, go to the edge of teh grille trim on the hood in the middle, a little to the right the drainage hole there you stick a screwdriver in there the clip is there its not hard to feel out with your finger
Answer: (to the title of this thread) Yes, and VERY easily
So I finally had a chance to get outside today and take a better look at my grill, rather than the past week where I was looking in a poorly lit garage after coming home from work. After getting on my back and looking up at the grill from under the car, I easily loosened the four screws which allow for the horizontal bar containing the "A" emblem to be removed. I then found the little tabs along the V shaped trim and again, easily popped that out. Then I worked on the other pieces (strip that runs along hood and strip above rear license plate) but these weren't really the topic of discussion.
Took me tops 10 minutes for the horizontal bar and V trim. And I didn't remove the bumper. So for those of you who insist on taking off your bumper, you might want to consider doing it the fast and easy way...by not removing it! I honestly can say you're wasting your time. I didn't struggle to work around anything, I didn't have to bend or force anything, and when it was all said and done, nothing broke!
So in conclusion, for anyone who is just seeing this thread, if you want to remove these trim pieces, it can easily be done without removing the bumper. My .
I do thank everyone for their comments and suggestions, especially Jesstzn who told me the easiest way to access everything is from underneath the car
4drviper (09-13-2017)
thanks for the insight, and quick question:
are the clips holding the center crossbar and the V trim same as the one clip in the center of the hood trim?
Let me know if this helped.
Actually I successfully got the hood trim off I need to get the v and crossbar
are those held by "clips"? And after I take the v off can I just clip it back into place w/o anything else?
To get the piece off, get underneath your car in day light and reach up to where the trim is. with a flat head screw driver, push the tabs in and push out at the locations shown in the illustration. get out from under the car and guide the trim out the rest of the way. and yes, after you take the v off you can clip it back into place
For the crossbar, no there are not clips. see this scan: http://img.photobucket.com/albums/v2...repl20-129.jpg
To get this piece off, again, go underneath your car and reach up to the grill. feel for the screw locations (6 total) and remove. try and use a small socket and ratchet bc it might be easier than using a phillips screw driver. Then go the front of your car and pull the piece off. that easy.
let me know how it goes...
ok i think i just found some clips, i found the top one from underneath, i have a question, its like a vertical piece of metal, how do you unclip it? i tried pushing it, but tdoesnt seem to do much? ima create a DIY for this after i figure it out
never mind see the clips with a mirror
but still cant figure how to unclip em... i tried pushing, but they wont come out, especially the top ones on the very sides of the v taht are like embodied in the grill cover
hey man i only can hold your hand so far and then the rest is up to you, lol. once you find those tabs, put a little muscle into it, just don't force it too hard. look at the diagram again to see how the tab latches on. it's self explanitory. you're gonna have to essentially squeeze the tab until it looses contact with the grill by pusing the tab to the side with a flat head and then push outwards. keep in mind you are working in the cold and it is plastic. i did it in 35 degree weather no problem. i've been on business travel all week otherwise i would have posted some pics and maybe a DIY by now, but i'll prob get around to it when i'm home. i just don't know how many people would care about this DIY since so many swear by removing their bumper :shakehead...
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
