Programming a rolling code
I'm having problems programming a rolling code for my garage door opener. I'm following all the instructions and still a no-go. Anyone else having problems?
This is kind of long, but the manual is either unclear or wrong with its programming instructions. Here goes.
To program Homelink, see page 145 in the owner’s manual. Before starting, you should erase any previously learned codes by pressing the two outside buttons on the HomeLink transciever for about 20 seconds, until the red light flashes. Release the buttons and proceed to step 1.
Also remember that once programmed, you have to keep pressing the button on your homelink for 1-2 seconds for it to work. It is not just a quick push like you are used to on the original remote.
Steps 1-6 are required for both rolling code and non-rolling code transmitters.
1. Unplug the garage door opener motor from the house current.
2. Hold the end of the garage door opener remote control 2 to 5 inches from HomeLink. Make sure you are not blocking your view of the red light in HomeLink.
3. Press and hold the remote control button and one of the HomeLink buttons at the same time. (Note: Canadian owner’s, see manual for additional instruction.)
4. The red light in HomeLink should begin flashing. It will flash slowly at first, then rapidly.
5. When the red light flashes rapidly, release both buttons. HomeLink should have learned the code from the remote control.
6. Plug in the garage door opener motor, then test the HomeLink Transceiver button by pushing it. If the button does not work, repeat this procedure to train again. If it still does not work, you may have a variable or rolling code garage door opener. See if you do by pressing the HomeLink transceiver button you just trained. If the red light blinks for 2 seconds, then stays on, you have a rolling code garage door opener. Go to step 7.
For rolling codes, you have to go through the instructions from number 1-6, and then start the rolling code procedures as follows.
7. Find the Training button on the garage or gate opener. Press and hold the button until the light next to the button comes on or blinks, then release it. You then have 30 seconds to complete the next step.
8. Press the button you just tried to train two times, holding it 3 to 4 seconds each time before releasing. The training light on the opener goes off. (Some systems may require you to press and release the button up to three times.)
9. Press the HomeLink button again to operate the garage door or gate opener.
If you have a problem or for more information, call HomeLink at 1-800-355-3515 or visit their website at www.homelink.com
key
"Before starting, you should erase any previously learned codes by pressing the two outside buttons on the HomeLink transciever for about 20 seconds, until the red light flashes."
this is the key above
I had no luck til I cleared homelink as described
Who cares
this is what worked for me
But it is good to know they worked.
Go to http://www.homelink.com/program/programming.tml To view more information than the manual provides.
Thanks!
Jamus22
06-11-2023 10:08 AM
joflewbyu2
10-08-2015 11:16 AM
