Preparation for a 2,000 mile road trip
Old 05-03-2012, 11:42 AM
JJH
JJH's Avatar
I will be going on vacation at the end of the month and in total will be doing about 2,000 miles of driving not including the driving that I do while I'm down there. I would like to go through everything on the car and make sure that it's in pristine condition so that I have nothing to worry about. If anyone could shoot me some pointers or things that I should check out before I go, that would be awesome. The car has 135k miles on it right now.
Here's what I was thinking:
-oil life is @30% right now. I'll be changing the oil to Redline synthetic and tossing in a Royal Purple filter.
-Tranny fluid is due for another 1x3 change with 2 Type-f and 1 lightweight type-f. Pressure switches I will probably hold off on until after the trip
-Brake fluid needs to be flushed
-Coolant needs to be flushed.
-Tires are brand new, good in that department.
-I'll be doing a full detail before I go.
-Brakes/rotors appear to be in good condition
Anything else that I'm missing?
Old 05-03-2012, 11:45 AM
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
Seems like you got it all covered OP. That's all I'd look for before a long trip. Maybe double check tire pressure?
JJH (05-03-2012)
shenrie's Avatar
I didnt see any hookers or blow on your checklist.
tire pressures for sure and when was your last alignment?
The following 2 users liked this post by shenrie:
JJH (05-03-2012), justnspace (05-03-2012)
the overexplainer
ez12a's Avatar
depending where you're driving, you might want to protect the front end with painter's tape (and if you dont mind the look).
Bug splatter can very well mar the finish on your front end, which would make the whole wash/detail a wasted effort. Bug splatter is probably 2nd only to bird poo in terms of potential damage. Driving just 1000 miles from LA to SF and back i had a ton of bugs.
JJH (05-03-2012)
Old 05-03-2012, 11:52 AM
JJH
JJH's Avatar
Not sure when the last alignment was. The tires were installed and alignment was checked about 1k miles ago. Everything was perfectly in spec.
JJH
JJH's Avatar
I was going to take a couple bottles of PAM spray with me to coat the front end every time I stopped to get gas.
Old 05-03-2012, 11:55 AM
the overexplainer
ez12a's Avatar
mmm maybe give this http://www.rainx.com/products/Bug_Tar/Shield.aspx
a try
Old 05-03-2012, 11:58 AM
I'd say you're okay against bugs if you're going to wipe it down every fill up. Just use the windshield sponge thing
Received 16,265 Likes on 11,974 Posts
are you going to be cooking with your TL?
I'm with Shenrie, you'll need some coke to drive that 2,000 miles in 1 day.
Old 05-03-2012, 11:59 AM
Needs a 930
BeezleTL85's Avatar
Pam? Lol I have never heard of such a thing. Does this work? Seems like it would be messier than just tapeing it up.
Old 05-03-2012, 12:25 PM
JJH
JJH's Avatar
^I'm not sure, someone else suggested it awhile ago.
Oops, almost forgot. I need to figure out why I'm not blowing cold air when the A/C is on.
Old 05-03-2012, 12:29 PM
That is something you do need!
Old 05-03-2012, 01:09 PM
JJH
JJH's Avatar
Yeah, don't want to be in 90 degree weather without AC.
As for fluids, what fluids are recommended for brake fluid, engine coolant, and power steering fluid? The threads in the 3G TL garage are all outdated and mostly applicable to 04-06 TLs which might be different since I have an 07 TL with the 3.5 vs the 3.2. I know the engines are the same, just different stroke.
So what fluids are recommended for brake fluid, engine coolant, and power steering fluild?
Old 05-03-2012, 01:12 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
1. motul 5.1 brake fluid (get 3 500ML bottles if you're doing an entire bleed...can only buy it online)
2. honda type II engine coolant (honda dealership)
3. amsoil synthetic PSF (get a turkey baster and empty the PS res, then refill with amsoil...can only buy it online)
don't use the turkey baster for cooking afterwards.
JJH (05-03-2012)
Old 05-03-2012, 01:15 PM
JJH
JJH's Avatar
Any reason I can't use the turkey baster for cooking afterwards?
Old 05-03-2012, 01:17 PM
BANNED
^bc that's gross.
Old 05-03-2012, 01:18 PM
you'll have power steering fluid flavored turkey!
Old 05-03-2012, 01:50 PM
insxtc's Avatar
lol
Old 05-03-2012, 01:56 PM
your car isnt special.
its the same.
all those past threads apply to yours.
The following 2 users liked this post by justnspace:
ggesq (05-03-2012), JJH (05-03-2012)
Old 05-03-2012, 02:05 PM
MandoTL's Avatar
I know, my sister when she visits down from Sacramento to Ventura County, her car is a brand new '12 Ford Fusion, pearl white, and didnt have a clear bra on it, bugs everywhere!!
I of course always clean and detail her car and asked her to save up for a clear bra since she does lots of highway driving, she made an appointment a week after her visit. Now her whole front hood and bumper are protected.
Wish I had the money to do mine, but it already has tons of rock chips, no bugs. So will leave like that and plan to get it repainted.
Old 05-03-2012, 02:08 PM
The following 2 users liked this post by Undying Dreams:
justnspace (05-03-2012), paperboy42190 (05-03-2012)
Old 05-03-2012, 02:10 PM
^pics of said clear bra on sister.
paperboy42190 (05-03-2012), Undying Dreams (05-03-2012)
Old 05-03-2012, 02:26 PM
MandoTL's Avatar
The following 2 users liked this post by MandoTL:
Acura_Dude (05-03-2012), justnspace (05-03-2012)
Old 05-03-2012, 02:27 PM
All in good fun haha
Old 05-03-2012, 02:28 PM
MandoTL's Avatar
LoL yep!!! I know.
Old 05-03-2012, 02:42 PM
DaeHanMeenGuk's Avatar
its the same.
it's special to him!
Old 05-03-2012, 02:57 PM
Guiltyox's Avatar
My MDX had the same thing when I first bought it (I have an MDX and a TL-S). Acura fixed it immediately, citing a stuck relay. Might want to check that out, if you're sure your coolant/Freon levels are good.
Old 05-03-2012, 03:00 PM
TLer trash's Avatar
Has the timing belt been replaced? Check the spare tire, especially pressure, and make sure everything you need to change a tire is in the car and working. Wheel lock key? Thinwall socket for aftermarket wheels?
Old 05-03-2012, 04:13 PM
turbo_oxide's Avatar
It's just 2k... if you maintain your car regularly as scheduled, just go and enjoy.
This reminds me of people who take 5 bags of clothes for a 2 day trip.
The following 3 users liked this post by turbo_oxide:
Acura_Dude (05-03-2012), DaeHanMeenGuk (05-03-2012), justnspace (05-03-2012)
Old 05-03-2012, 04:37 PM
Jesstzn's Avatar
One alternate to the painters tape is black electrical tape .. just as much work to put on and your not limited to time before it becomes hard to get off ... 5 rolls for Walmart at $1 roll will cover the frontall area just like a bra.
I'm not sure on the Pam thing .. what happens if it rains ... will it run everywhere?
I do know that 4 Star Ultimate Paint Protection is great resisting bugs for the first couple of washes, Just a quick wipe with a M/F cloth and a QD and the bugs are off .. You could even reapply every second gas stop .. would take 5 min. on/off.
Old 05-03-2012, 04:58 PM
JJH
JJH's Avatar
its the same.
my car is special
For example, the Tl-s has a different # of pressure switches and from what I have read, the are in different locations. How am to know if there are other minor differences between the TL-s and the base TLs?
Old 05-03-2012, 05:05 PM
Majofo's Avatar
Received 11,842 Likes on 8,573 Posts
That's a lot of prep for a trip. Painter's tape over the front or clear bra as was mentioned.
Old 05-03-2012, 05:16 PM
Pat04TL's Avatar
In addition to what's been said, a good cell phone and paid-up auto club dues wouldn't hurt. Or you can add towing onto an auto insurance policy for like $1/month. Probably won't need a tow, but obviously it can get expensive if you break down in the boonies...
Old 05-03-2012, 05:22 PM
Majofo's Avatar
Majofo packs heat when he's out and about.
Old 05-03-2012, 05:23 PM
Yumcha's Avatar
Received 22,855 Likes on 14,003 Posts
And don't forget your credit card!
Old 05-03-2012, 06:08 PM
Majofo's Avatar
What are you doing over here Yummy?
Old 05-03-2012, 06:22 PM
Moved to the LOU
twigglius's Avatar
Gallon of water and a fleshlight...
Oops, I mean flashlight.
The following 3 users liked this post by twigglius:
Acura_Dude (05-03-2012), justnspace (05-03-2012), Undying Dreams (05-03-2012)
Old 05-03-2012, 08:34 PM
JJH
JJH's Avatar
Any reason you suggest using the Amsoil PSF over Honda PSF?
Old 05-03-2012, 08:46 PM
endles/acura's Avatar
3 things always overlooked
-Tire pressure (that includes the spare tire)assuming the four wheel alignment was already done and the wheels balanced.
- Always have handy a tow truck phone number (AAA) just in case.
- Have some good music with you (2,000 miles with bad radio can definitely suck)
Most of all enjoy the trip,this cars can take the abuse.This will be a good time to learn more about your vehicle.Good stuff.
Old 05-03-2012, 09:02 PM
my car is special
the threads still apply to you.
JJH (05-03-2012)
Quick Reply: Preparation for a 2,000 mile road trip
