Premium vs Regular Fuel
Thinking of buying an 07 TL w/ Nav and noticed it requires premium fuel. With the price of gas skyrocketing I'm having a little concern. Has anyone tried using regular and if so, how did the car run?
Hi and welcome to the forums. I moved this thread from the Frequently Asked Questions forum to the applicable 3G TL forum . Please click here to read the announcement at the top of the FAQ Forum for more information.
We bought our 07 TL w/Navi on 31 March and I asked the same question of the dealership. Both my salesman and the finance officer (both drive TL's) said they run regular with no problems. My wife asked my son-in-law, who is an ASE Certified Mechanic, and he told her that if the Owner's Manual calls for Premium that's what she should use... So, now my wife is paranoid and I'm stuck paying for premuim fuel!
Moral of the Story, be careful who you ask, and who's around when you ask it!
19UUA75577A
The owner's manual states the minimum octane rating that should be used, which I believe is 91. Since many gas stations sell 87, 89, and 93, you're stuck buying premium, but you can find stations that sell 91 if you look around.
In most cases the vehicle will run on lower octane by 'decreasing performance' which is a fancy way of saying 'when you run low octane fuel in a motor with 11:1 compression, it's going to detonate before the spark, and we'll have to pull back on the timing'
run anything less than 91 and expect problems and any warranty issues it will come into duscussion
TLs have required it for years, thats part of owning a sports car
Originally Posted by Hooligan317
*warning* generalization coming *warning*
If you can afford the TL, you can afford to put premium in it.
The vehicle is designed to run on 91 or higher octane but can run on regular octane fuel in case the others are not available. When a lower octane fuel is used the vehicle needs to make certain adjustments to work with it and the result is a decrease in performance (including a decrease in gas mileage). Whatever money you save at the pump you'll lose by driving the car getting less MPG. Over time you'll also get excessive carbon build-up from running a lower octane fuel.
+1. Your compression ratio is 11:1. So it needs high octane fuel (fuel more resistant to detonation with increased temperature and pressure) Higher the compression ratio, the higher the temperature and pressure of the compressed mixture in the chamber. If you detonate the mixture before the spark from the plug, you can most definitely expect problems. Our acuras, i believe, retard timing so as to compensate for lower octane fuel....Also, someone in a past thread did a mini-study about the cost of running 87 v. 91 octane. Its cheaper to run 91 octane. More miles per gallon, less money per gallon!
that would be $0.20/gallon or more around here, which is a bit more than 'a few cents'.
I've seen articles where the dealers/sales/etc folks say 'use premium' whereas the Honda engineers who designed the motor say 'I use regular'.
Go figure.
As to how it runs, I would say 'lethargic'. Better on midgrade, happiest on premium.
Go figure.
When gas was .99 a gallon for regular and premium cost 1.19 I never heard anyone complain about the 20% more money they were spending on premium.
Now that gas is 2.99 and premium is a whopping 6 or 7% more at 3.19 everyone starts complaining about having to use it. I just don't get it.
If you can't afford an extra 2 bucks everytime you fill up your car I suggest you buy one that doesn't take premium.
The TL will run just fine on regular, but it's going to cost you in performance and fuel economy. You'll probably end up spending more on fuel if you run regular.
07 KBP TL Type S
You're not really saving that much more to make a substantial difference. My roommate and I talk about it all the time and we've calculated that you'll save maybe $100 a year, of which that really isn't that much, with all things considered.
Like others have said, if you can afford to purchase a TL, you can definitely afford the extra few dollars. So, save money and get less mpg or pay more and get more mpg? Almost works out the same, but in the long run -- which will be better for your engine? I say go with the premimum.
But are you really saving any money when you go regular? You get a few more mlies to the gallon on premium, and this washes out the extra amount paid for the premium, and I think (geez, i cant find that post of the mini study! ). You actually save like 2 cents a gallon going premium (if i remember the post correctly)
I guess I'm at a little higher altitude.
19UUA75577A
Originally Posted by MisterFubar
All I can get around here is 87, 89, and 91. Very few of my area stations have 92, and a couple of the racing shops have 104 or 114.
Just don't get excited and mix race fuel with standard gasoline, or if you do, make sure it's unleaded. Anything higher than 94 octane is just going to smell good
Originally Posted by Cocoa
Leaded fuel wont hurt. Valve seats for today's cars are made harder to compensate for the unleaded fuel of today. Leaded fuel in the past provided cushion for the valves back then.
BUT, it will kill your 02 sensors.
I like to whistle in my
Even at .20/gallon even if you fill up completely we're talking $2.50 a tank.
Search the couch.
Search the couch.
I would advise not to cheap out because its gonna cost you down the road. Yes, someone did mention its a Honda engine but it's ECU and engine are set a little differently than a regular honda. My 04 V6 Accord was made to run on 87 and performed no differently as far as mileage goes. It's almost like the gas evaporated with high test/grade gas. The only difference I could feel was when I cleaned the fuel injector, change the oil, change the air filter and clean the throttle body/butterfly.
Im not going to lie, it irritates me too but i get over it once get back in the car and behind the wheel
I've done my own "research" on the regular vs. premium debate. I travel frequently between Mountain View and Sacramento (125 miles each way). I normally use regular and I will fill up in Sacramento, reset the trip computer, set the cruise at 67 and when I get home my trip average MPG is always 32. The last two trips have been with full tanks of premium and the mileage...32! As for the difference in power, I just don't notice a difference although I'm not the type to Stop Light Grand Prix every other sports sedan out there, just a few . Another thing I have always wondered is why the 3.0 liter engine in the Accord produces 244 HP on regular for a specific output of over 81bhp/ltr where our TL needs premium for 258 hp from 3.2 liters for a LOWER specific output of 80.6bhp/ltr. Anyone have an answer?
Make MyTL Great Again
As it has been mentioned already. You shoudl use Premium/91/93. If you don't the car will lose performance (horsepower/torque) and gas mileage will be worse. There are plenty of threads on this issue if you search for them. Members have done there own testing and discovered that the drop in MPG is not worth what you 'save' by using regular...you lose more mpg (meaning you will drive less of a distance) then your 'save'.
a) They'll say anything to get the sale.
b) They are probably driving the dealership's cars...they don't care about them
The bottom line is that it is not worth using regular. But in a pinch it will be fine.
This is directly from the Acura Owner Link maintainence FAQ section:
"Refer to your Owner's Manual for the pump octane number recommended for your Acura. Use of a lower-octane gasoline than recommended can cause a persistent, heavy metallic rapping noise in the engine that can lead to mechanical damage."
wow........already two pages of comments on this subject that has already been beaten to death many times before. It all comes down to the fact that you will not save any money using regular fuel because of the decreased efficiency.
Originally Posted by leedogg
How come nobody ever complains about the $10 per gallon bottles of water???
Buy the high octane and stop crying Or ride your bike
Better yet go buy a Toyota Hybrid.
Just got my TL and needed to fill up today. It was on E with the light on and all, so I pulled into a gas station and filled it up. It stopped a 13.5 gallons, but I know the tank is 17 according to the manual. Is that normal? Is there really around 2.5-3 gallons left when the light turns on?
If you really want to find out, put a lawn mower gas can in the trunk. When the light comes on, reset A or B trip odometer and run until its gone. But do it when its warm out. You never really want to run your tank out. Especially if its cold out and you might have condensation in the tank.
Using lower octane rate gas is one of the worst things one can do to the engine. Probably even worst than not changing oil at all. An I bet that some of guys who are using regular change synthetic oil every 3000 miles.
Search the couch.
Search the couch.
Originally Posted by chasieboy
Wow..Im surprised 2.50/Gallon..here in cali bay area its 3.56/g
