Power steering rack leak
My TL has been in the shop for the last 5 days to repair a problem with the power steering rack/unit that was leaking and causing a loud, grinding noise upon startup. It must be a pretty uncommon problem b/c they had to special order the part. When I did a search, I didn't find a lot of people having this problem (how was I so lucky
Can somebody who knows more about cars than I do explain what exactly this problem is and if I should be concerned. It doesn't seem like the type of problem that should be occuring in a brand new car with only 5,000 miles.
CEO, Team Anthracite
Actually, they almost always special order those non-regular maintenance parts.
A power steering unit that leaks mean the power steering fluid which helps you move your steering wheel from side to side doesn't get to the motor where it needs to. That's probably the cause of that loud grinding noise - no lubrication.
There have been a few other reports of this problem so do a search and see what their symptoms/resolutions were. Good luck with that!
05/5AT/Navi/ABP/Quartz
Don't feel bad it's just as Lore mentioned. Mine has been in since last Wednesday for the temperature flat line problem. Navigation system unit is on national backorder. I think everybody stocks damn near nothing.
I'm not pissed because I have on 05 non-navi loaner with fewer miles than mine has. Lets just be glad we have a warranty to take care of this stuff.
But hell why be glad you have a warranty, you are entitled to service. I would be worried that they put the same level of quality back in the car and it dies again. This time maybe even after the warranty is up...
More toys->More to break Oh well, Warrentees rule. Im just worried about small problems that screw over entire systems in about 10 years. Although if my dad really loves this car I can probably get him to get the next gen after this is paid off.
Systems Overlord
I wouldn't worry about it too much. Mechanical parts break and not everyone manufactured is going to work for as long as it should. The chances that you're going to have a problem with the replacement is slim.
mike from annapolis
05-07-2017 08:21 PM
