Power Source
Old Nov 17, 2007 | 02:45 PM
77donovan77's Avatar
....just dancing in
Question Power Source
Looking forward on during the Luminated Door Sills. Would like them to be on the same line with the Dome Lights.
Where is the best possible location in tapping into the Dome Lights......?
And can you tell me which colored wires (pos & neg) is used for this mod...?
Old Nov 17, 2007 | 03:09 PM
01tl4tl's Avatar
Look at the top of the thread list for gen3
DIY section and check there
If they dont have one, gen2 does and should help you out
Old Nov 17, 2007 | 03:37 PM
u1arunit's Avatar
Car Guy
donovan,
I just did this install last week. Firstly I don't reccomend tapping into the dome lights solely.
The directions that I used are here: http://www.sbadesign.com/acurazine/sills/
The transformers are wired to hot all the time and the trigger to turn them on is the grounding of each respective sill's door switch which goes to ground when the door is open. This way each sill only comes on when that particular door is opened.
Since the dome light power side of the circuit is under control a different way, as it dims out etc, it might go thru some sort of module and it's probably best not to power directly from that source. I would need to check my manual to be certain but I think I'm correct here.
Hope this helps!
Old Nov 18, 2007 | 02:54 AM
....just dancing in
Originally Posted by u1arunit
donovan,
Hope this helps!
Thank you so much.....that will help me alot
Old Nov 19, 2007 | 12:43 AM
sunny201's Avatar
A J35A8 EG civic is in
thats the same website I got my directions off of.. works like a charm and i love the way they look
knight rider
Mar 4, 2016 08:59 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
