Portable Battery Trickle Charge
v 4910shp/19,600ft-lb v
I'm going on a trip and I need to leave my car untended for a few months. I bought one of those portable battery chargers (the one you can plug into the power outlet) since I don't want to disconnect my battery. My question is, does the key in the ignition have to be turned to "On" for the power outlet to accept power from the portable battery unit?
Thanks in advance for any help!
Most cars have the lighter socket on with the key out, so one
can light their doobies...
Not all cars though, you have to check it.
Most battery tenders have a light that lights up when they are charging.
If the car is outside, think about a solar charger, works off sunlight...
no fire hazard, cant overcharge the battery...
Brett
Brett
Alright, well, I'll plug it in and see if the light comes on. I was thinking about a solar charger, but I am putting a car cover over the TL so that avenue won't really work
... Hopefully, I can save myself the time of inputting the codes and radio stations with this battery charger...
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
The only way to do it would be to modify it to have power permanently.
Do a search here on the forum for this mod as someone did this recently.
Best regards
frenchnew
Not a Blowhole
I have used Deltran "Battery Tenders" for many years, on all my stored cars, motorcycles, and even my "flamed" hot rod lawn mower. As an EE, I can attest to the strength of the engineering of these devices - they have improved over the years, and will extend battery life while keeping the car fully charged. You connect to the battery with a pigtail connector that is foolproof. All the talk of cig lighter connections is moot if you go with a quality product.
The current draw on modern cars is substantial - the batt can lose 5-10% a week. Once it drops below the critical voltage threshold, you will get the dread click-click when you turn the key (or press "Start" on your Ferrari or S2000).
Battery life is also greatly extended, by reduced sulphation of the lead plates. I have a batt on a bike that is over 10 years old and its specific gravity and nominal DCV are as new.
MetalGearTypeS
08-29-2016 08:28 PM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
