PLASTIDIP long term...
Old Jul 26, 2012 | 10:23 PM
08AcuraTL3's Avatar
Looking for info from all plasti dip users. How has it held up? Anyone done it on their rims? Anyone done a black roof with it on a WDP car? Considering doing it on my rims since it is completely reversible, but I really want to know how it has been holding up. Thanks
Old Jul 26, 2012 | 10:34 PM
McCollins23's Avatar
Chapter Leader (Midwest Region)
It has held up pretty well on my grill. I don't think it looks good on the roof as it will appear splotchy. A few members have tried the roof and it didn't look great.
Old Jul 26, 2012 | 11:05 PM
08AcuraTL3's Avatar
yea didnt really plan on using it for my roof but was just curious since some people actually use it to paint their entire car ha. thanks man
Old Jul 26, 2012 | 11:20 PM
Domm's Avatar
You need to apply 5 coats minimum, allowing 10-20 minutes between coats, if you plan on driving on the highway. I've heard that some people with plastidip rims say that its still looking good after a year.
Old Jul 26, 2012 | 11:43 PM
ez12a's Avatar
the overexplainer
it has been holding up fine on my grill minus a small scratch when I hit some road debris.
Old Jul 27, 2012 | 06:03 AM
jonmizu's Avatar
With one can of plasti dip you could redo your grill atleast 20 times haha So "long term" is normally not the question besides people plasti dip because it's a temporary option. Like I want black wheels for now but if I ever change my mind I can peel the plasti dip off
Old Jul 27, 2012 | 06:20 AM
1black_seven's Avatar
Slot Machine Lubricator
I did a shitty job on my grill. And by shitty I mean only two coats and I rushed to get it done in under an hour. I plan to redo it.
Im going to redo the entire thing proper next week.
Its worn off from road debris in the right upper corner but you cant really see it until you get up close.
Old Jul 27, 2012 | 08:43 AM
UA6~RBP's Avatar
-Brandon
Plastidip can last years if done properly (5-6 even coats) especially on body panels like the grill, trim, or emblems.
The only place that Plastidip won't hold up well on is on the wheels. Road debris and normal use will likely tear the Plastidip making you have to redo it. However, a lot of people tend to dip their wheels in the winter to protect from road salt. There are reviews on YouTube that say their Plastidip wheels last forever, but it's inexpensive to redo, so I wouldn't give that much thought.
Old Jul 27, 2012 | 08:27 PM
LoveMyTL-S's Avatar
I did my rims about 4 or 5 months ago and so far so good. The beauty of Plastidip is that you can always touch them up and respray.
Old Jul 28, 2012 | 09:27 PM
08AcuraTL3's Avatar
Thanks for all the replies guys. Now another question, whats your opinion on black type s rims with a red time attack style on WDP TL? or how about black rims with white time attack stripe around wheel to match car? ive seen red on a black tl-s and it looked really good.
ive seen red on a white 335i coupe and it looked really good too surprisingly.
Old Jul 28, 2012 | 09:34 PM
08AcuraTL3's Avatar
white time attack:
http://farm6.static.flickr.com/5254/...496a7e5e6a.jpg
http://www.mycarportal.net/wp-conten...manzara_04.jpg
red:
http://www.m3post.com/forums/showthread.php?t=144882
Old Jul 28, 2012 | 09:51 PM
Chad05TL's Avatar
I got a can of this stuff it says on the can it has many uses. It said it was good for sound deadening too. So I sprayed the inside of my new speaker box, but it is very fumey. Need ventilation. But if you want to use it on a hood or a large area, I would opt for using something similar to the Di-noc paper stuff. I got the cheaper stuff at Pep Boys and it looks just like the more expensive Di-noc stuff. You can get a piece large enough for a TL hood for $50. They sell the flat black stuff too that is not "carbon fiber like".
Old Jul 28, 2012 | 09:55 PM
08AcuraTL3's Avatar
thanks man, but I was pretty much only considering trying it on my rims.
Old Jul 29, 2012 | 08:02 AM
GeeteeDan's Avatar
I Like turtles
My grille and rims have held up fine. And I've tried the roof, don't do it. Looks like crap
Old Jul 29, 2012 | 02:29 PM
sauceja's Avatar
Desert Life Sucks!!
My lower grille needs to be re-done and I had a piece on my grille where the tape made a nick that has gotten worse from washing car alot.
I used about 5-7 coats or so with about 10-15 minutes between coats.
Will need to be re-done. Otherwise I would recommend some kind of clear coat.
Old Jul 29, 2012 | 04:48 PM
TVL65's Avatar
I'm about to find out as my son just did my hood trim on my 07' TLS, he did 5 coats each 30 minutes apart. I had an auto body shop paint the entire grill 2 years ago & now its chipped, the grill itself isn't bad but the hood trim was due to highway rocks. Rather then sand down the hood trim I had him buy a new one for $40. I'd like to do the entire grill but right now will wait to see how the PlastiDip holds up. It seems flexible so shouldn't get chips. Looks nice too.
Old Jul 29, 2012 | 08:09 PM
08AcuraTL3's Avatar
thanks guys
Old Jul 29, 2012 | 11:49 PM
Bruce Banner's Avatar
As I was reading this thread, I was JUST thinking about plastidipping the wheels for winter salt.
My old car I brought out to the midwest for the first time, after 2 winters of salt, the coating was pretty much done.
Are people applying it while the wheel is on the car
Old Jul 30, 2012 | 07:14 AM
LoveMyTL-S's Avatar
The roof would probably look good if you sprayed a gloss enamel OVER the plasidip. That way you can still peel it if you don't like it or want to change it later.
Old Jul 30, 2012 | 07:30 AM
LoveMyTL-S's Avatar
Check out this vid:
Old Jul 30, 2012 | 07:39 AM
I think the problem is an even spray pattern.
the roof covers a lot of real estate.
if you go to dipyourcar.com, you can see their process on how they DIP THE WHOLE ENTIRE CAR.
they use a conventional air compressor/spray gun.
Old Jul 30, 2012 | 11:41 AM
LoveMyTL-S's Avatar
Very true. On a large area like that I'd use a sprayer of some sort.
Old Jul 30, 2012 | 12:37 PM
MEKO's Avatar
^ keeping the spraying distance far is one hint if you don't want to waste money on those pro products on dipyourcar website.
will take time and cans
Old Jul 30, 2012 | 06:31 PM
Pennstater's Avatar
Has anyone dipped their interior panels to change their color (like from tan to black)? I saw the below images on another thread of the center console silver trim dipped, and I have to say it looks pretty good. I was wondering how well this stuff would adhere to our plastic interior panels.
No clear. Just sprayed and reinstalled
Old Jul 30, 2012 | 06:40 PM
That's a good idea, I might try the smoke though.
I was leaning towards some duplicolor metallic paint.
That should hold up.
Old Jul 30, 2012 | 06:45 PM
MEKO's Avatar
There are better wrapping vinlys and stuff for that part or other interior parts that could make it look richer.
I like the bright version of this. Stands out
Steven Bell did nice job on it as well.
Old Jul 30, 2012 | 06:46 PM
MEKO's Avatar
I wonder how would smoke with metalizer would look on that side trim..
Old Jul 30, 2012 | 06:59 PM
Pennstater's Avatar
That Plastidip black looks like a pretty good match to the TL's black dash and the radio - even in the texture department. I wonder if the all of the tan panels painted Plastidip black (and the tan carpet, seats, headliner, etc. remain tan) would look too hokey? Too much black perhaps?
I have had great success using Duplicolor Adhesion Promotor and Duplicolor Trim Paint on my front grill and on the front and back trim of the A-Spec pieces. It has held up very well. I'm not sure how it would hold up on interior pieces though???
Forgive me if I am thread jacking by posing questions about using Plastidip on interior pieces.
Old Aug 1, 2012 | 08:43 PM
ashdec87's Avatar
I've had my grill plastidipped for about a year. After about 25K miles of highway it just needed some touchup, but otherwise was ok.
Old May 23, 2013 | 04:09 PM
Nick216's Avatar
The Boss
Any1 find that it takes the paint off your rims. Now hear me out. I plastidipped 2 of my rims black and today i peeled it off. Both rims are completely silver, while my other 2 are the normal type s gunmetlish. Any1 gotten this... Cus its weird
Old May 23, 2013 | 04:30 PM
simran4h's Avatar
yyou should use vinyl for your roof
Old May 23, 2013 | 05:38 PM
sauceja's Avatar
Desert Life Sucks!!
Take wheels off card put them on a box or old sheet or something for overspray. Buy 3x5 index cards and place between rim and tire to keep tires from getting overspray on them.
I taped off the barrels as I just wanted the faces to get painted. But I did a flashy color so I didn't want to paint the whole rim.
Rims take about 1 can per rim to do it right with 3-5 coats.
If going with a color besides black buy 2 cans of white to do the base coats with. Will help colors stand out more.
Old May 23, 2013 | 07:22 PM
TheLowLife's Avatar
^ /thread
Old May 26, 2013 | 06:07 PM
jstins0n's Avatar
curious as to what color you did yours??
Old May 26, 2013 | 06:15 PM
TheLowLife's Avatar
From his build thread:
Coils issue resolved, RDX covers installed and rear calipers painted.
Cleaned it today but need to clay bar it due to requests from others.
Old May 26, 2013 | 09:27 PM
zachlone's Avatar
Pink wheels that's sexy!
Old May 26, 2013 | 11:04 PM
TheLowLife's Avatar
Piiinnkkk it's like red but not quite...
Old May 27, 2013 | 05:04 PM
zubi23's Avatar
just platidipped my rims and grill...the rims were really easy except i got some plasti dip inside the inner rim which I didnt want because its uneven...
the grill i put 5 coats and the left side of my grill didn't turn out too good
[IMG]PLASTIDIP long term...-dwmypsw.jpg[/IMG]
[IMG]PLASTIDIP long term...-uvrtuvb.jpg[/IMG]
emailnatec
29
Sep 28, 2018 04:27 PM
spoiler900
Oct 10, 2015 06:48 PM
polish_pat
Sep 30, 2015 12:22 PM
kb1rl
Sep 30, 2015 10:17 AM
