Parts Needed for 105k Service
Old 01-06-2015 | 06:13 PM
JPerkMr954's Avatar
Hello Again everyone.... Happy New Year!
Ive been debating paying the dealer for this service or having a mechanic do so to save some money. Im just trying to get the best price for this service, which will be the first big investment.
Is there somewhere I can find out if there is like a "KIT" that can be ordered with all the parts needed for the service or where can I find all that is apart of this service and I can possibly ordered from an acura parts websites found on this site. Im past 105, not worried but I dont want to keep going too much longer, and I feel i might need a tune up of sorts anyways.
Old 01-06-2015 | 06:27 PM
nfnsquared's Avatar
Gates or Aisin kit. Do a search, tons of threads on this.
Old 01-06-2015 | 06:43 PM
WDPanda's Avatar
I purchased all on Rock Auto.
-Aisin timing belt kit
-Aisin water pump kit
-NGK OEM plugs
-Gates tensioner and pulley (kit)
-Gates Micro V belt
-OEM thermostat and gasket from dealer
Got a mechanic familiar with Hondas to do the work. Under a grand for all parts and Labour listed.
Old 01-07-2015 | 04:22 PM
nvasion's Avatar
damn so cheap to do the job in america...
im from canada and thejob cost me 1450...
Timing belt
Drivebelt
Water pump
Adjuster timing belt
Timing belt tensioner
Timing belt idler pulley
Thermostat
Spark plug-6
Old 01-07-2015 | 04:30 PM
polobunny's Avatar
Registered Bunny
Timing belt
Drivebelt
Water pump
Thermostat
Spark plug-6
That's the price of the job + the parts. Bring the kit yourself and you'll save money. Also get to know a garage, it's useful.
Old 01-07-2015 | 07:11 PM
JPerkMr954's Avatar
-NGK OEM plugs
-Gates Micro V belt
The dealer is only charging 750 if im not mistaken with changing the water pump. Im trying to get this under 500.
Old 01-08-2015 | 01:21 PM
truonghthe's Avatar
I can get all of that list under $500 either with OEM or good name brand like Gate or OEM supplier.
Old 01-08-2015 | 02:32 PM
DMZ's Avatar
DMZ
Head a da Family
Paul, our mechanic in NJ, gets $400 for labor including a valve adjustment. Can't beat that one!
He does however recommend only using the Aisin kit for the timing belt/water pump job.
Old 01-08-2015 | 05:59 PM
nfnsquared's Avatar
Originally Posted by DMZ
...He does however recommend only using the Aisin kit for the timing belt/water pump job....
Why?
Old 01-09-2015 | 04:46 AM
WDPanda's Avatar
Why?
It's OEM
Old 01-09-2015 | 08:53 AM
nfnsquared's Avatar
It's OEM
The water pump isn't. Aisin hasn't been OEM for several years now.
Old 01-13-2015 | 11:03 AM
JPerkMr954's Avatar
Ive been looking on EBAY for these "KITS" im going to compare pricing the needed parts individually to buying a kit and then see which is better... Ive already gotten a labor rate I like for installing...
Old 01-13-2015 | 11:17 AM
nfnsquared's Avatar
You're wasting your time....
Old 01-13-2015 | 12:17 PM
JPerkMr954's Avatar
because........
Old 01-13-2015 | 01:07 PM
polobunny's Avatar
Registered Bunny
because........
Gates kit w/ pump is $131 on RockAuto.
Old 01-13-2015 | 04:40 PM
JPerkMr954's Avatar
what I just found was following:
Timing Belt
Idler Roller Pulley
Tensioner
Water Pump
Hydraulic Tensioner
Camshaft Seals
Crank Seal
Serpentine Belt
Am I missing something?
Old 01-13-2015 | 05:16 PM
WDPanda's Avatar
Really? Even our 04-06 TL's?
When my waterpump was taken out it was identical to the Honda pump. Only difference was the OEM had Honda logo moulded into the metal. Gates has a different propeller and such.
Old 01-13-2015 | 05:19 PM
WDPanda's Avatar
Timing Belt
Idler Roller Pulley
Tensioner
Water Pump
Hydraulic Tensioner
Camshaft Seals
Crank Seal
Serpentine Belt
The cam and crank seals will be a pain in the ass unless it's already leaking.
Spark plugs are missing.
The kit for timing belt comes with an idler pulley and tensioner.
the kit for serpentine comes with idler pulley and a tensioner with pulley.
Old 01-13-2015 | 05:41 PM
JPerkMr954's Avatar
Sounds like you said that the only thing missing was spark plugs... that was what is all included in a kit i found on ebay... which im going to order.. and add in a thermostat...
Old 01-13-2015 | 05:56 PM
acrdr's Avatar
This is why i go with aisin kit
as you can compare old parts which were removed from a 3g tl which were oem and new parts which come in an aisin kit
the last pic of the non aisin water pump came out of a 4g tl so Honda might have changes supplies but i still installed an aisin kit for the 4g tl
Old 01-13-2015 | 06:21 PM
nfnsquared's Avatar
^^^ Yes, Acura stopped using Aisin water pumps several years ago...
Old 01-13-2015 | 06:23 PM
acrdr's Avatar
I will use aisin over anyother aftermarket kit
DMZ (01-17-2015)
Old 01-13-2015 | 06:25 PM
nfnsquared's Avatar
I wouldn't, but that's up to you. I have 85K on the Gates kit, no issues...
Old 01-13-2015 | 06:36 PM
acrdr's Avatar
Its cool
Everyone has a perference
Old 01-17-2015 | 09:38 AM
DMZ's Avatar
DMZ
Head a da Family
Correction: The water pump IS!
What's important is that Aisin was the OEM supplier when our cars were made, so by buying the Aisin kit, you know you're getting original parts. Paul, our mechanic in NJ, recently showed me a water pump he took out of an Accord that had BOTH the Aisin and Honda names etched on it, and only recommends the Aisin kit. The Aisin kit also comes with Koyo bearings as Koyo is also the bearing original supplier. The ONLY Gates part to consider would be the Serpentine (main drive) belt.
Old 01-20-2015 | 09:23 AM
javiersanchez06's Avatar
8th Gear
I have read in a few threads that people have gotten the 105k timing belt etc. change in Honda dealers and that the parts were of course the same OEM parts but at a cheaper price due to getting it done at a Honda dealer as oppose to an Acura one. You should try calling some local Honda dealers and see what they have to say, hope this helps.
Old 02-16-2015 | 09:51 AM
JPerkMr954's Avatar
Im going to look for ASIN instead of gates. There are some FULL OEM parts kits on ebay for high 200s or low 300s. I'm going to read into it more and then purchase.... I went to the dealer and they gave me a sheet full of repairs needed...
Old 02-16-2015 | 04:04 PM
N1h1l1ty's Avatar
Confusing Name Guy
I'd love to see some links in here for a complete kit, whichever you go with. I'm thinking of stockpiling the parts even though I'm only at 60k myself.
Old 02-17-2015 | 05:00 PM
JPerkMr954's Avatar
This is one of the ones im considering:
http://www.ebay.com/itm/Genuine-Aisin-Timing-Belt-Water-Pump-Kit-Honda-Acura-V6-Factory-Parts-/171540570047?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CMake%3AAcura%7CModel%3ATL&hash=item27f09d5fbf&vxp=mtr
Old 02-17-2015 | 05:02 PM
JPerkMr954's Avatar
another:
http://www.ebay.com/itm/GENUINE-OEM-HONDA-ACURA-V6-COMPLETE-TIMING-BELT-WATER-PUMP-KIT-FACTORY-PARTS-/400366752056?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CMake%3AAcura%7CModel%3ATL&hash=item5d37b7d138&vxp=mtr
Old 02-18-2015 | 03:48 PM
Chef107's Avatar
Which one did you end up choosing? I'm looking to purchase the 105k kit from somewhere and want to go about it in the most price efficient way possible.
Old 02-18-2015 | 05:34 PM
JPerkMr954's Avatar
Havent bought yet, it will be either of (I need to just confirm on the cheaper it is OEM 100%) then when Uncle Samuel gives me my $$ IM ORDERING!!
Old 02-18-2015 | 09:58 PM
876_CGP_TSX's Avatar
Just ordered for my 08 KBP TL type S and my brother-in-law's 05 TL.
I don't believe you can do it a more cost efficient way with OEM quality than the method I chose:
Aisin Kit EBay which includes the below - $185 shipped
•AISIN Water Pump
•AISIN Hydraulic Tensioner
•Koyo Idler Bearing
•Koyo Tensioner Bearing
•Mitsuboshi Timing Belt
•Water Pump Gaskets & O-Rings
Engine Timing Belt Kit with Water Pump Aisin TKH 002 | eBay
Bando Serpentine Belt (Amazon) - $ 20 shipped
http://www.ebay.com/itm/Serpentine-Belt-Rib-Ace-Precision-Engineered-V-Ribbed-Belt-BANDO-6PK2135-/151539125142?pt=Motors_Car_Truck_Parts_Accessories&hash=item23486f8b96&vxp=mtr
OEM Camshaft & crankshaft seals - $19 shipped
91213-RKG-003 x 2
91212-R70-A02 x 1
http://www.ebay.com/itm/161588769651?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I Got 6 NGK 6994 spark plugs at advance auto for $40 ...($60 bucks with $20 speed perks discount)
So minus the plugs your looking at $224 total for parts...I noticed you live in South FL and said you already have a labor rate that you like.... but I guarantee I can get my friend who currently works as a senior tech at Acura to do the job for a better rate....dealership quality, small shop price...PM me if and when you are interested
The following 3 users liked this post by 876_CGP_TSX:
BMA1078 (02-22-2015), JPerkMr954 (02-19-2015), WDPanda (11-03-2017)
Old 02-19-2015 | 10:30 AM
JPerkMr954's Avatar
That is even cheaper than the entire kit that was cheapest on EBAY as a whole set by 50 bucks.... So thanks for that!!! I will shoot you a PM about that.. let me ask... what area is this person located in?
Old 02-19-2015 | 11:07 AM
polobunny's Avatar
Registered Bunny
Check RockAuto too.
Aisin kit is $178 w/ pump, Gates kit $138 w/ pump, shipping $6. Pretty much the same price, but you buy from one centralized place instead of different sellers.
My 2 cents.
Old 02-19-2015 | 11:10 AM
JPerkMr954's Avatar
Looking at your list again, is that timing belt an OEM belt manufacturer? I dont see that name on the parts site, I see UNITTA
Old 02-19-2015 | 03:17 PM
coykiam's Avatar
Just recently had mine done at 99,xxx miles when the MID alerted me. Cost me $1,300 w/o water pump and thermostat. A little expensive than others but was well worth it, had it done at an Acura dealer. Car runs like its brand new!
Old 02-19-2015 | 09:36 PM
Mitsuboshi is an OEM Belt Manufacturer for Honda/Acura.
From what I have seen they mostly make drive belts/ compressor belts , see below:
BELT, COMPRESSOR (MITSUBOSHI) | Genuine Acura | 38920-RCA-A03
Although the actual OEM belt for the TL is made by UNITTA, gives me piece of mind knowing the belt from the AISIN kit its from an oem belt manufacturer used by Acura on current models.
As it relates to my friend - he is down in Miami , but guarantee you that his price/quality work is worth the trip from the 954 to the 305!
Old 02-19-2015 | 09:51 PM
Thumbs up
Also if you doubt the AISIN kit check the reviews on amazon...81 reviews, 5 star overall....best bang for the buck
Amazon.com: Aisin TKH-002 Engine Timing Belt Kit with Water Pump: Automotive Amazon.com: Aisin TKH-002 Engine Timing Belt Kit with Water Pump: Automotive
Old 02-19-2015 | 11:37 PM
JPerkMr954's Avatar
Oh Aisin I know is the way to go, I was just concerned about timing belt it seems the difference in the price for the cheaper I posted versus your set is about the cost of an OEM timing belt...
Quick Reply: Parts Needed for 105k Service
