Painting Intake Manifold
Old Jan 24, 2011 | 07:20 PM
rtibbitts07's Avatar
Looking into painting my intake manifold this upcoming week and wondering if any other members have input on this.
My main concern is paint type/surface preparation, I need to find a paint that will be fine with the heat that it will be exposed to in the engine bay, and also a corresponding clear coat.
For surface preparation, should I just clean the part with soapy water followed by rubbing alcohol? Or should I do a solid sand paper job on the entire upper cast surface for a smoother look?
The final concern, and also the one that could prevent me from even trying this, is will it be too cold for the paint to properly dry? I can heat the garage I plan on doing this in to 50* or so, but not sure that is enough, any minimum temperature advice?
And yes, I plan on removing the manifold and doing appropriate masking, just looking for tips from anyone else that has done this.
Thanks in advance.
Old Feb 24, 2011 | 07:39 PM
Sezniko's Avatar
Whatever I do what I want
When I did the IM spacer mod I painted the spacer and the entire intake manifold.I hand sanded the manifold,then used high temp paint from autozone. You should paint at 65 degrees and higher in general. Every can should have the temperatures it can be used in and the drying times. Caliper paint should work for this job too.
This has pics of the manifold removed during painting.It shows what I taped off.
https://acurazine.com/forums/showpos...&postcount=777
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
