Oznium Angel Eye Ring Size?
I need help from someone who knows or can measure the Diameter of the Oznium or umnizta Angel Eye rings, both the LED version and the CCFL thin rings if you have both. The outside diameter (mm) will be fine if anyone could provide this information!!! Thank you!
Thanks man. Didn't you have CCFL's before the LEDs? I'm confused JNC just said the diameter of the Umnitza CCFL were 72mm. I've seen pics of both the CCFL and the LED rings and the LEDs are for sure more then 2mm smaller. I'm looking for this diameter in the pics below.
The reason Im asking is because Im going to have a company custom make me a set. Im just needing the size so I can save myself from having to mail out my headlights and be out of a car so soon.
Also what kind of light does this person have in the turn signal part, the piece to the far left?
The car in the pic is mine. (thanks for the free advertisement Roger )
The headlights are Type-S. As far as the rings are concerned, I believe they are the exact same size. I don't know for sure because they were not compared to each other before installaton.
The light on the corner is a type II switchback parking light that turns amber when the signal switch is activated. It returns to pure white when the parking switch is on.
Contact headlight guru JnC. He does mods on member's headlights and comes across halos pretty often. He might be your best bet.
good luck.
good luck.
ExcelerateRep
10-14-2015 08:20 AM
