Oil Change Schedule
Old 06-23-2008, 09:29 AM
  #41
cbbutlercm's Avatar
Originally Posted by I hate cars
Increased vibration and decreased performance from 2,200 miles on the oil is completely in your head. Impossible. Think of all the extra drystarts from the new filter being empty.
if you cant tell when your vehicle is running differently then you might want to turn your AC off and roll the windows up, drive around with new oil and then again right before and after an oil change. the reason your vehicle doesn't start instantaneously when you turn the key is to allow oil pressure build up prior to starting, so i'm not too concerned about dry stars except during the winter when the oil is cold.
Old 06-23-2008, 02:07 PM
  #42
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
Come on people....
What exactly do you think happens to the oil in 2,000 miles that makes your car run differently? It is in your head. You would be better off seeing a shrink than changing your oil that often.
Most people can't tell the difference in how the car runs between a 0-20 and a 10-30 weight much less the same grade with a couple miles on it.
The motor turns over 2 revs before starting. When you change your oil filter, it still has to fill up the filter before it gets pressure. Watch how much longer the oil pressure light stays on when you install a new filter. That's a dry start and a couple revs before the engine fires makes no difference.
I'm very old school when it comes to changes. I get laughed at for changing a premium synthetic oil at 5K but there comes a point when you're doing more damage than good.
Old 06-23-2008, 08:00 PM
  #43
B16 Swapped TL
SporkLover's Avatar
Here is some reading to ponder.....
Longevity tests on Mobil 1 and a LS1 car (Camaro Z28)
Phase I http://neptune.spacebears.com/cars/s.../oil-life.html
Phase II http://neptune.spacebears.com/cars/stories/mobil1.html - 18,000K miles, no oil changes, only top off and a single filter change.
Interesting what they found..... as the oil aged the wear and tear decreased on the engine...... they predicted an 8k oil life, but went all the way to 18k.
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
robm
09-18-2015 07:53 AM
HydrasunGQ
09-14-2015 10:14 PM
datadr
09-12-2015 09:12 PM
Quick Reply: Oil Change Schedule
