New Wheels! New suspansion or comp flash needed?
A-SpecBlackout
Im purchasing new wheels! 20" BOSS 327's with a 40 offset...After longggg searches ive found the ones i want! ... Im not sure if i need to make modifications or if im good with my current settings and suspension...
ALSO:
-Do I need or should i consider new suspension? (I currently have A-spec suspension...)
-Would I need to re-flash my computer because of the size increase? (i currently have aspec wheels 18")
-Think Ill need a camber kit? Or will a good 4 wheel allignment be sufficient?
-I have the choice or Toyo or Nexen tires...Im thinking Toyo...any recomend size with the most tire that wont rub? (I live in Jersey!)
LET ME KNOW WHAT YOU GUYS THINK!
ALSO:
Too Fast TOO FURIOUS
Originally Posted by NighthawkA-Spec
1) 20" BOSS 327's with a 40 offset. Im not sure if i need to make modifications or if im good with my current settings and suspension...
2) Do I need or should i consider new suspension? (I currently have A-spec suspension...)
3) Would I need to re-flash my computer because of the size increase? (i currently have aspec wheels 18")
4)Think Ill need a camber kit? Or will a good 4 wheel allignment be sufficient?
5)I have the choice or Toyo or Nexen tires...Im thinking Toyo...any recomend size with the most tire that wont rub? (I live in Jersey!)[
2. A-spec is fine unless you want to get rid of the 4x4 look.
3. nope. but the speedo will be off by a little.
4. don't need alignment unless you go lower than 1" and do suspension work.
5. need input from ppl with 20s.
btw, nice wheels!
A-SpecBlackout
Originally Posted by enigmaos
1. how wide are the wheels?
btw, nice wheels!
btw, nice wheels!
the wheels are 8.5 inches wide i dont think ide be doing myself any good if i went wider although it would look pretty nice...
nuldabz
09-03-2015 05:49 PM
