New owner - maintenance
2006 TL, 6-speed, ~86k miles. I'd like to do a bunch of preventative maintenance right away. So far I'm thinking:
Thoughts? Anything else I need to add?
- Air filter
- Cabin Filter
- Fuel filter
- Trans filter
- Trans fluid
- Spark plugs
- Engine oil + filter
- Coolant
- PS fluid
- Brake fluid
- Clutch fluid
On my Miata I change them every 30k or so. Then again, the TL is pretty different - apparently I don't need to replace wires to go with the spark plugs??
Registered Bunny
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I would do an inspection on the engine mounts and the front lower control arm bushings. The front LCA bushings are known to go quickly and it's likely at 90K they could require replacement.
I'd also consider checking out and or just straight up replacing the engine torque dampener. When I pulled mine at or before your milage, it was toast. Like completely worthless. XLR8 makes a quality upgrade that's not too expensive.
And being a manual you may want to consider doing the slave cylinder check valve delete right from the get go.
I'd highly recommend just getting the HT spec kit from Marcus.
https://www.heeltoeauto.com/drivetra....1.ss.....html
It made it short and notchy yet still silky smooth for me. Combine that with the check valve delete and it really makes it fun to blaze through those gears.
There's certainly no quick fix to substantially change the feel of a gearbox but while the stock shifter in the TL isn't bad by any means, any improvement would be welcome. Speaking of which, do all TLs' clutch pedals engage at the very top of travel?
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Curious as to why you are changing the fuel filter? I know you are doing preventative maintenance but unless you the fuel pressure drops below a specified value, I'd leave it alone.
justnspace (09-24-2015)
I also thought the transmission filter was one of those 'never needs replaced' type items...
^OP drives a manual... But yea small job I guess.
Aren't the filters like built in on the 07-08 so technically they never get replaced?
Why would I do the timing belt 20k early? This car will probably only see 5k a year, so doing the belt now is essentially four years earlier than necessary.
Just check the belts. If they look fine, which they probably do, you have some time to plan ahead. But I would do it sooner rather than later.
He's right though I wouldn't flush the coolant if there is no need. Just wait for the 105k.
I believe, don't quote me I haven't had my coffee yet, that the big service is either 105k miles or 7 years. Well you're 2+ years beyond that.
I bought mine at 86k (now at 118k) and here's what I've had to do:
105k service (tbelt, wp, spark plugs)
Front and passenger side motor mount
Obviously oil changes and brake changes as needed.
And that's it! Runs like a champ and has never let me down. I would highly recommend the clutch check valve delete (just did this yesterday), but obviously not required maintenance. A lot of the stuff on your list I wouldn't bother with... just inspect and if it looks good, leave it be.
:edit: and as others have mentioned, use GM syncromesh for your trans fluid change.
mine is middle/bottom of pedal.
Thanks for all the replies!
Updated to-do list:
Definitely enjoying the car over the last two days that I've had it. I do have a vibration under braking at highway speeds though and the e-brake is weaksauce so I'll look into that too.
- Air filter
- Cabin Filter
- Trans filter
- Trans fluid
- PS fluid
- Brake fluid
- Clutch fluid
- Inspect engine mounts front LCA bushings
- Timing belt, water pump, and coolant flush
- Check brakes
Updated to-do list:
- Air filter
- Cabin Filter
- Trans filter
- Trans fluid
- PS fluid
- Brake fluid
- Clutch fluid
- Check brakes
Does the 6mt TL have a trans filter? I have a 5AT so maybe the manual guys can chime in. I know my 6MT Z does not have one.
Good luck with everything, are you going to DIY or take to a shop? Or both? Haha.
Going to ditch the clutch slave cylinder check valve this weekend and bleed the clutch fluid while I'm at it. What's the capacity of the entire system (master, slave, lines, etc)? I.e. how much clutch fluid do I need to buy?
I don't think it uses a lot. I can't recall what the "total capacity" in the system is. But you won't use much.
Purchased my 06 TL 6spd 12/23/15 from FL, and drove home to MN. When I got home, had about 120k. Needed engine mounts, tensioner, engine torque dampener. Front LCA bushings probably should be replaced (I feel excessive body roll), shouldn't be the suspension. I've also looked into the slave cylinder check valve delete AND the slave cylinder replacement. Haven't done either of the last two, nor my front LCA bushings, but probably should. Hopefully make it through this winter, if not, will do if my clutch pedal acts up again.
Good to know. You put it so simply and plainly. I'll definitely do that come spring. Any concerns to worry about?
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
