Need a real quick radiator question answered
Sorry if i haven't been thorough in my search but time is of the essence.
Would it do any damage to my radiator to add the little bottle of prestone radiator flush they sell to my distilled water while flushing my system?? (drain, fill with distilled water and additive bottle, drain, fill with distilled water only, drain, fill with coolant)
I dont want to screw anything up and it was just after reading about issues with non honda coolant i just wanted to check.
if gen3 same as my gen2,,,
there is an engine block drain bolt on the rear of engine
Open that to really get everything, including some sand from the original casting!!
Make sure heater is set to full hot the entire process
Burp the air from rad per book or trapped bubbles will screw with you
changed the coolant on mine after 6 years and it was perfect inside the radiator-
spotless clean metal
Just yesterday I flushed my radiator and engine block and refilled w/ regular 50/50 from Peak. What exactly could be the problem if you don't use Honda / Acura Coolant? I'm thinking about doing this drain of radiator and engine block once a year so if the issue is contaminants in the generic coolant, then I wouldn't have to worry since I'll be swapping out coolant every year.. am I correct to assume this?
It's doubtful there will be any short term effects but in the long run I would not use anything but Acura/Honda fluid.
I do a radiator drain and fill every other year. Doing it this way will never require a complete engine flush and it's overkill. The sand that came out on the first drain and fill made me wish I had done it sooner. I assume it's left over from the casting process.
my opinion- as long as it says APPROVED for Acura then its fine for coolant
having silicates or not is the differance
coolant is good for 5 years then goes acidic,,, in an aluminum environment
how they think 7/105 before change is crazy talk~~
Are there any approved aftermarket coolants? The PEAK one I bought says compatible w/ American and Import vehicles. Not sure if it contains silicates.
אני עומד עם ישראל
An article I came across, interesting read http://mr2.com/TEXT/HondaCoolant.html
Coolant flush?
This would probably be the only time I would recommend an OEM fluid. When I changed out the coolant in my TL @ ~58k I went straight to the dealer to pick up the Acura blue stuff.
if trying to flush system you must open the engine drain block
does the stuff you used says its ok for acura- in named car makes?
does it says contains silicates?
not sure since I'm not home and the bottle has been since thrown away and picked up by garbage collectors. I will def. remove it though and replace w/ Acura / Honda fluid. Does flushing w/ water seem like a bad idea though?
אני עומד עם ישראל
As long as it's distilled you're fine. No need to introduce a bunch of minerals to the system with tap water. If I had to choose between the two I would say you're better off not flushing than using tap water to flush.
אני עומד עם ישראל
^^ good catch I forgot to mention that, make sure it's distilled.
or go to the parts store and read another bottle of the stuff
Could be fine- many of them are compat with our needs now- many cars use same stuff as acura
draining the rad will not remove all the fluid- must remove from engine drain block via drain bolt on rear of engine block
i wouldnt throw anything in there it seems the blue stuff they use in these cars has an additive for the aluminum not to corrode under normal conditions.... so if u throw water in there itll probably just evaporate out of the system.....or contaminate the crap out of it.....ive seen a tl having its cooling parts replaced because the dude was in a bind and needed something so he added water...bad move he let the car sit 3 or 4 days without handling his issues with it and it crapped out rust. it was at the dealer the other day
