in need of mpgees!
http://www.youtube.com/watch?v=lw2naDdfdwM&NR=1
here's another where the guy even has a TL! but I've been told that acetone will dick up your seals, and any rubber components in the fuel system. I used it for a while in my 350z and it really did increase the mileage but I didn't want to f up the internals. if I ever lease a car you can believe I'll be using acetone, lol!
What About Acetone?
There has been some controversial talk about adding acetone to your gas - some have claimed that adding 2 ounces of pure acetone to every 10 gallons of gas will increase fuel economy by 25%. Something about the acetone allowing the fuel to fully vaporize in the combustion chamber, thus making it more efficient.
I'm not ready to try this, but if anyone has tried it I'm sure we'd like to know what impact its had on your fuel economy.
Best thing to do for better MPG, increase tires to 35PSI cold, change air filter, coast to lights, don't rev over 2.5K, and reduce some weight. I took out my spair tire, owners manuals (have digital copy) and someday will upgrade to a lightweight battery...
ahh yes weight reduction, familiar with that when i used to go to the track with my old stang..same idea different purpose lol...what about C/A intake or even just a K&N filter?
also, how easy is it to change ur cabin filter?
anything I can do to crank out a couple more MPGs outta my 04 TL!?
Also, use the cruise control if you can (recognizing that with ever-increasing traffic it can be very hard to do this). It will hold your speed a lot better than you can do on your own.
Originally Posted by 1995hoo
Drive your car at the slowest speed that allows you to use your highest gear without lugging the engine or having to downshift. This principle applies to any car, not just the TL. I find that on most roads, that speed is around 65 mph in the TL with the 6MT, and certainly it's not less than where the 100 km/h mark is. I've gone 58 to 60 mph in 6th on flat roads, but with any sort of hill beyond the slightest minimal grade it needs to go down to 5th and then you start using more gas.
Originally Posted by Walshstl
55mph@1500rpm for 5AT TLs. I think I read taht somewhere on here
Accelerate slowly, coast as much as possible, and drive at the minimum speed supported by your highest gear. Thats about all you can do. Having a clean air filter is not important, and increasing tire pressure is minimal unless you do it to an unsafe degree. Although low tire pressure is definately bad. In general stick to the manufacturers specifications.
I am averaging about 28mpg on my 5AT and I drive about 60% town 40% highway. Really, thats damn good gas mileage for a pretty big car.
Originally Posted by TzarChasm
Accelerate slowly, coast as much as possible, and drive at the minimum speed supported by your highest gear. ....
I don't know whether by "coast" you mean "coast in neutral" the way the so-called "hypermilers" like to do. I assume not, but if you do, note that doing this is illegal in most states for safety reasons. It's OK to coast up to a stop when you shift to neutral as you approach a red light, but the "hypermilers" advocate shifting to neutral on downhill grades and then rolling down the hill out of gear and doing other things like that.
I think when he says coast, he just means foot off the accelerator as often as possible while cruising around 30 MPH, or just coasting to a stop instead of gassing till the last minute and then breaking afterwards....which I think is retarded!
Here's one:
Sit in your car and grab the steering wheel. Ease in your seat and close your eyes and pretend you have started your TL and youre driving it. Imagine all the scenery you pass by. If you are doing errands, pretend you are driving to the bank, grocery store, etc.
Repeat as necessary. If you want to go to Vegas, then ROAD TRIP! Imagine you have an endless tank of 93 and you're driving down the highway @ 130 w/ no cops.
The best thing here is you just did the maximmum MPG w/o spending a dime and your TL is newer because of the miles you didn't put on it.
PLUS you just accumulated a full tank of $6/gal of 93.
TL drivers never put 87 in their tanks, even if 93 goes up to $10/gal.
Originally Posted by AcidHorse
Here's one:
Getting an after market intake and/or getting a wider exhaust pipe with a racing muffler will help. However, either of these will also make the car run louder and void the warranty. Each one of them might give you a 1-2mpgs. I did both of them on my old grand am. Found the gas millage change as an unintended benefit.
Does anybody know if this is legit? There's an add for it on acurazine.
http://slrmotorsports.com/shop/index...uct_detail&p=5
I looked into the slr chip. It seems to be another one of those things, that just tricks the car into thinking the air temp is colder than it is. It's amazing me how no one's come up with an actual ecu upgrade for this car.
that is absolutely what I mean. Coasting in neutral uses more gas than leaving it in gear.
I shift into neutral and let the car coast whenever I see a red light up ahead. The RPM's drop to around 750 or so, the same as if I was stopped at a red light.
No aftermarket mods void the warranty unless they're a direct cause of the problem.
Originally Posted by DMZ
Not true, at least with a 6MT.
so if I was getting pulled in neutral while my car is running for 60 miles, it would use more gas than somebody driving the same distance?
Originally Posted by Tripnbeats
yea that doesnt make sense....it makes sense that u waste more gas when u have to match ground speed and gear speed when u go back into gear from coasting but not just coasting.
I was referring to this comment
If you want to talk about net fuel usage while towing a car, I have no f'ing clue.
a car idling uses ~.5 gal/hr
if you are idling at 70 mph (coasting), you are using less gas than driving at 70 mph.
Its all about the pedal.
