need help with if these rims will fit
Hi im just wondering if these rims would fit my 2005 acura tl. It has the Brembo brakes upgrade. The rims are 8" x 8.5", 5x114.3 Bolt Pattern, 72.6mm Hub with +45 offset.
Correct me if I'm wrong, but those are the same specs as the 18x8.5 a-spec wheels with the exception of the hub size so they should fit. Hub size is easily solved with hubcentric rings.
However the spokes could still be a problem so knowing the exact wheel would help.
skyflakes12
06-19-2011 01:06 PM
Brian_C6
01-26-2004 11:28 PM
