MT Fluid/Spark plug/Clutch Quiestions.
Veeeee Tec
Hey guys. I currently have 97k on my TL. I want to switch over to the GM Syncromesh fluid and replace my spark plugs w the OEM NGK's. Do you guys think it is worth it at 97K?
Also, my clutch has been a little weird in 3 rd gear, i feel some slippage. How much do usually OEM clutches cost and i think i want to replace the flywheel as well.
Thank you.
Thank you.
i just had a warranty clutch, pressure plate, flywheel replacement done. i think the total would of been close to 1600 to 1700 from what i saw of the bill before i got mine with NC on it.
How did you get it covered under warranty??? cuase i have the same car as you and they are saying that its not covered and my clutch is starting to go at 60,000 Kms
