Moving to Chicago & Looking at a 3rd Gen TL
Hi Guys and Gals,
New member here so please I apologize if this question has been asked before. I am moving to the Chicagoland area and currently have a 2016 GMC Sierra, a little impractical in the big city... I have always liked the 3rd Gen TL and it seems to have a timeless shape along with Acura's legendary dependability. Seems like a perfect city car! My question is, when looking at used 3rd Gen TL's is there anything common that I should look out for when looking at these cars? It appears that there are still quite a few great examples of these cars for sale.
Thanks in advance!
muhsfink07
Thanks in advance!
muhsfink07
Latent car nut
Hi Guys and Gals,
Thanks in advance!
muhsfink07
Thanks in advance!
muhsfink07
- Are you looking for an Automatic or a Manual?
- Are you looking for a higher end TL (i.e. the TL-S which has more power)?
Regarding what to look for, there are a lot of threads here on shopping criteria; here are a few:
- Has the timing belt and water pump been changed and when?
- If you're looking for an automatic, the 2007-2008 models, both base TL and the TL-S, are considered more reliable.
- If you're looking for an automatic, does it have a service record for the transmission maintenance?
- If you're looking for an automatic, how does it shift when you drive the car?
- Check the dash over the glove box for cracks around the air bag.
- Check the leather seating for cracks or tears.
I guess I should have been more specific. I would be looking at one of the older low mileage automatics. I don't need the Type-S so I'm not looking at one of those. One thing that I have seen are quite a few of those older early model 3rd gen's with low mileage, under 75K, being listed for under 10K. I would definitely go over it with a fine toothed comb understanding that it is a used car. However I was wondering if there were common issues to be especially mindful of.
Thanks!
Thanks!
Latent car nut
The most significant issue to be aware of on the 2004-2006 TLs with an automatic transmission is the transmission itself. As I understand it, it is a "when not if" prospect; when the tranny goes Tango Uniform, your options are a standard remanufacture, an upgraded remanufacture, or my favorite, a swap to the AV6 transmission from the 2006-2007 V6 Honda Accord models. As I understand it, the AV6 swap is pretty much a bolt in replacement and MUCH more robust than the standard TL tranny.
Interesting that the Accord transmission is considered a stringer unit. Is it identical to the 06-08 TL transmission?
Are some of those lower mileage 50-65K mileage older models to good to be true? I know that cars need to be driven to be reliable so crap doesn't dry out.
Also, would it be wise to factor in the cost of the car the cost of replacing suspension bushings etc?
Latent car nut
At some point you will need suspension work; the suspension of my 2001 Accord is verging on needing the bushings replaced now after 195,000 miles (next annual inspection most likely), the bushings on my 2006 TL with only 122,000 mile on it are still good to go.
I would only get an 07-08 for the transmission alone.
