Motor mount DIY or pointers/tips
Old 03-18-2011, 12:46 AM
that ONE RED tl
DimwitRj's Avatar
I'm going to attempt doing my mounts next week, does anyone have a DIY (don't believe I've come across one) or any tips? Especially for the rear mount... TIA
Old 03-18-2011, 02:31 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
o man the rear mount is a PITA....i highly recommend paying $80 for a shop to do the rear.
front is okay. remove the radiator fans for more clearance and make sure you have a variety of extentions and sockets.
side mount is EASY i can do it in like 10 min. only 2 bolts holding it on bottom and 1 bolt on top and very easy access.
i noticed you're in socal, lemme know if you need any help.
Old 03-18-2011, 02:38 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
This might help: https://acurazine.com/forums/3g-tl-problems-fixes-114/replaced-my-motor-mounts-pics-inside-772642/
Old 03-18-2011, 12:27 PM
that ONE RED tl
DimwitRj's Avatar
Thanks to the both of you.. well technically I'm doing it at my uncle's shop with his and my brother's help. Just getting some pointers because he specializes in DOHC 4cyl Hondas (ex-pro drag racer).
As far as the rear, it can be done through the top of the engine, correct?
Old 03-18-2011, 12:28 PM
Old 03-18-2011, 12:36 PM
KN_TL's Avatar
It's honestly not that bad. I did mine with just a jack and stands.
Old 03-18-2011, 05:12 PM
Dogmatic Dinosaur
jda123's Avatar
If your uncle has a shop, then this will be no problem. Some extensions, socket u-joints and air tools will make this a breeze.
Old 03-19-2011, 10:27 PM
I have car ADD
BLACKURA_NY's Avatar
like others said... side takes 2 minutes... front, isnt too rough.. the rear is a BITCH
honestly, the best method is old school... get a floor jack and some 2x4's.... put the 2x4 between the oil pan and the floor jack, and jack up the engine slightly (or lower it) to help with aligning the mount
what happens to some people, is they remove the mount and then the holes wont line up... it can become a real bitch to fix
Old 03-19-2011, 11:43 PM
that ONE RED tl
DimwitRj's Avatar
Not looking forward to this at all... lol.
Old 03-23-2011, 11:04 AM
that ONE RED tl
DimwitRj's Avatar
Damn I'm sore as f***. Did all 3 of my mounts yesterday and took my about 4 hours. Even though I was able to utilize my uncle's shop I did 95% of the work because my brother and uncle were busy building a roll cage for another car.
Like you guys said, side was a breeze (I wish they were all that easy). Front wasn't a big deal after removing the radiator fans, I found that I couldn't remove the driver side fan without removing the top hose. The rear was a bitch, just because of the awkward positions you had to be in, other than that, they were all pretty straightforward.
What really gave me a hard time was probably the simple things. Banged up my finger removing the vacuum line from the front mount, and had to do the rear over because I pinched the vacuum line without knowing and tightened down the bolts $#!+.
Another pointer... the front and rear are filled with fluid so if they're cracked... don't turn them upside down. I made that mistake with the front mount while messing with the vacuum line.
Once all is down, enjoy the clunk free driving and rattle free cold morning starts! ...and take some pain relievers the next day because you will be sore.
Old 03-23-2011, 11:48 AM
sddale's Avatar
How much has your idle changed? Is there still some vibration?
Old 03-23-2011, 08:42 PM
I have car ADD
wait. did you replace with OEM mounts, or did you go with Innovative...?
I had Innovative 75A mounts on my 3G TL-S... oh my what a world of difference
Old 03-23-2011, 08:51 PM
that ONE RED tl
DimwitRj's Avatar
I went with OEM, didn't want any rattles.. but I guess that doesn't matter right now... my trans just died.
Old 03-23-2011, 09:34 PM
mindanaomoro's Avatar
What your trans DIED!!? another one!? how many miles? so sad to hear.
Old 03-23-2011, 09:51 PM
that ONE RED tl
DimwitRj's Avatar
96k, I have a thread in Problems & Fixes.
Old 02-02-2020, 11:59 AM
ThetypeSwithBadPaint's Avatar
do you still have your TL ?
Old 02-02-2020, 03:46 PM
Mine still going....
ThetypeSwithBadPaint (02-02-2020)
Old 02-02-2020, 11:39 PM
*how many miles on clock
Old 02-03-2020, 05:37 PM
DerrickW's Avatar
Would you mind expanding on this thought? I also have a 3G TL-S, sitting at 178k and I anticipate having a little play money in-pocket next month & trying to figure out some modest yet good bang-for-buck upgrades/changes.
Mike734
12-10-2021 01:25 PM
tsx_boy
12-13-2019 08:33 PM
08KBP_VA
10-22-2019 01:55 PM
Quick Reply: Motor mount DIY or pointers/tips
