moonroof deflector?
Back in a TL again.
are you talking about this
![](http://www.handa-accessories.com/pilot/visor.jpg)
if so it does work well i had mine on the 03 tl looks tacky but when you have your moon roof at tilt it works well in stopping the whistle at least for me, i took it off just because i don't like it but now i have to live with the whistle that i get.
The external plastic moonroof visor stops the wind noise that comes roaring in at freeway speed.
Without it- forget passenger or phone conversations with roof open
yes that's the one. it does stop the whistling at high speeds and keeps things quiet inside.
i was just getting sick of the look, but its function out weighs the form i guess...
19UUA75577A
I took the thing off of my 07 simply because I bought a 95 legend that had one a few years ago, and it had been on it since the car was new, the paint underneath it was destroyed.
If you're going to use one, I'd recommend removing it monthly and cleaning under it. Also, wax the paint, and use something like Meguiar's Vinyl/Rubber Cleaner/Protector to keep the rubber soft.
If I put mine back on, it'll only be for the warmer months, then it'll come off for the winter.
Has anyone else noticed that the black wind guard that pops up when the sunroof is open actually makes more noise up than down? Try holding it down while you're on the expressway, it's a lot quieter..
~Da Nocturnal Cheetah~
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
No one is going to see this, including you unless you take this off. On a black car that I have to constantly clean for obvious reasons, no way can I see the importance of adding a monthly detail like this! Especially after watching the service guys fight to get that damn thing on when I first got my car in November! I don't relish the task of taking that on just to be anal. Plus, I don't have the time. I am sure that what you said is true about the paint after years of it being present, but even when I sell it, I don't see them taking it off, and looking under that thing saying, "Houston we have a problem!" ...Just my
Oh, I almost forgot...I love mine! I use the BT (HFL or Jabra JX10) exclusively in the car and it would be hell without one with the top open!
Every post I've seen about a sunroof having a wind deflector installed has had complaints about whistling. A fair share of members have taken it off after installing it.
07 TL-Navi 5AT, NBP
I've been debating it, not for noise but for glare. On my '85 626 it helped 100% stopping the sun glare. On my '94 626 I ordered it at the same time I ordered the car. It was a lot 'shorter' than the '85 and did absolutely nothing for stopping the glare (could be sunroof and/or driver position). Additionally it ADDED that air pressure throbbing at low speeds with windows up, resolved only by cracking one of the rear windows.
My TL, sure I get glare, but don't want to disturb the clean roof lines, I just wear a baseball cap now (which happens to say Acura on it).
If you want to install the deflector and not worry about it scratching the paint, apply some of the clear bra material (3M Polyurethane) between the sunroof and the windshield and then the deflector.
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
From what I understand there is a rubber seal around the part that sits on the roof - to protect the car.........the deflector itself is held on by two clips that screw into the deflector and attach inside the roof opening
Originally Posted by ZippySLC
How does it attach to the car? I'm interested in one to cut down the wind noise.
![](http://i170.photobucket.com/albums/u272/psheu/P1040963.jpg)
Originally Posted by psheu
The deflector is held down by 2 clips that clipped onto the edge of the moon roof.
psheu,
First off, your car looks great!! Nice job.
Does your reflector completely stop wind (air and noise) from entering the car? My back seat passangers hate when I open the roof - of course I could put them on the bus...
![Wave](https://acurazine.com/forums/images/smilies/wave.gif)
Originally Posted by JoeyASPEC
Every post I've seen about a sunroof having a wind deflector installed has had complaints about whistling. A fair share of members have taken it off after installing it. ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
Originally Posted by warccm
psheu,
Does your reflector completely stop wind (air and noise) from entering the car? My back seat passangers hate when I open the roof - of course I could put them on the bus...![Wave](https://acurazine.com/forums/images/smilies/wave.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I ended up taking mine off my '05 because it had an irritating whistle, even when closed up. It is genuine Acura issue. It also has 4 clips, not 2. It didn't take long for the rubber seal to dig into the paint either. Once removed, you can't get rid of the grooves.
'05 6MT NBP
A-Spec suspension
K&N Typhoon intake
Michelin Pilot A/S 245/40/17
Debadged rear
V1 on the lookout
'05 6MT NBP
A-Spec suspension
K&N Typhoon intake
Debadged rear
V1 on the lookout
'05 6MT NBP
A-Spec suspension
K&N Typhoon intake
Debadged rear
V1 on the lookout
'05 6MT NBP
A-Spec suspension
K&N Typhoon intake
Debadged rear
V1 on the lookout
![what](https://acurazine.com/forums/images/smilies/what.gif)
'05 5MT ASM w/Navi Mod
A-Spec wheel, body kit, steering wheel
K&N air filter
Acura OEM Brembo Brake
'05 6MT NBP
A-Spec suspension
K&N Typhoon intake
Debadged rear
V1 on the lookout
'05 6MT NBP
A-Spec suspension
K&N Typhoon intake
Debadged rear
V1 on the lookout
haha j.k - but this is all i hear about it. I like the look of it, but I'm not going to do it.
Mistuh DRiiVA
i have the moonroof deflector on my 05 SSM TL and it poses no problesm to me. I still hear a little whistling sound, but not that noticable, i must say though, it really helps when the moonroof is open and your driving on the highway, which was the reason y i got it. I think it looks good too but everyone has thier own opinion lol.
19UUA75577A
Try the 3-step 3M products, just use it on the roof/affected area..
I think it's a cleaner, then an abrasive material (you'll see your paint color on the rag, that's scary), then a glaze to fill in the missing pieces. It's been a while, so I kind of forget.
update
Just to give everyone an update. i decided to remove the deflector for the summer at least. someone's post about the paint getting damage underneath it scared me. and guess what i find underneath when i remove the deflector? 2 lines from the rubber lining on the deflector almost scratching the paint...i'm going to zaino it this weekend, hopefully it comes out.
i will miss the quiet the thing brought at high speeds with the roof open. maybe i'll put it back on next summer.
Yes, I know this thread is old, but I am thinking about taking mine off now. I don't know why this guy took his off in the summer, when you traditionally have the roof OPEN, instead of the winter when you traditionally have it CLOSED???
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
At any rate, can you guys weigh in on why I should or should not take it off as far as functionality and aesthetics are concerned. I am really up in the air about this. I love to use the HFL, so if it would be a prob talking then I probably won't do it. But still...I'm beginning to think it looks better without. Just don't know if wind noise would be major with it off. Anybody???
H-E-L-PPPPP!!!!!!!
![Scream](https://acurazine.com/forums/images/smilies/scream.gif)
This is MY OPINION and I am not trying to PISS anybody off.
I HATE sunroof, side window deflectors, body side molding, pin strips, chrome door trim, etc.
FRIKEN UGLY. YUKKKK IMO IMO Do what YOU LIKE its YOURS....
If you do decide to take yours off and are happy with it off, I may be interested in buying it from you.
Take it off, leave it off.
First item I spot when a vehicle is coming towards me is the large glob on top of the roof. Take a look at the cars with the deflectors and note how many high priced luxury cars or sports cars have them.............Very, very few indeed.
As usual, just my
As usual, just my
I was having a great debate with myself over whether or not to remove the moonroof wind deflector. I'm going to keep it on for now. I was weighing the pros and cons, and the pros far outweigh the cons:
Pros:
1)I paid for it (lol)
2)Cuts down on overall wind noise
3)I can talk on the HFL with roof open (at least in the city, where I drive the most, haven't tested hwy yet)
4)Doesn't look hideous
5)If I remove it, there may be stuff to fix appearance wise from what others have said as far as paint loss or damage from rubber seal (see below)
6) No one ever said anything about it on here or real world before I mentioned it. So it can't be that bad!
Cons:
1)Aesthetics (disruption, tho not extreme, of roof line)
2)Apparently, as told by others here in 3G, the rubber seal eventually messes up the paint on the roof in that spot. That if you take it off after a couple years, there is some minimal damage there. In some cases biting into the roof. So, concern was there for them on resale value. I think that is not an area of concern if you don't take it off because how will you see it? The seal would be covering it. It's not like someone is going to say "Hey! Take that off so I can inspect the roof!" Plus, it's not a hardcore mod like a CAI. So I don't see the problem there with the seal damage thing.
No one has ever come up to me and said nice car, but it would probably look better without that damn deflector up there. Please remove that hideous monstrosity cuz I'm about to puke!! Yeah, nobody has ever said that. If someone were to say that, THEN, I may remove it! LOL!
So Stella keeps her accessory for now...
Pros:
Cons:
RAR
personally, I dont like them. Disrupts the clean lines of the car. I'm iffy on the window visors. Again I generally dont like things attached to the car, but they do give it a wider look.
Dark, I would at least take it off to check out the condition underneath, fix it up if necessary or at least begin some preventive maintenance, then you can put it on again.
So Stella keeps her accessory for now...![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
In your defense, I do believe the deterioration of the paint under the deflector would benefit you keeping it in place.
Why have a moonroof if your covering 30% of it.
You guys think it has deteriorated even though I just got this car last November past? I find that hard to believe. Why would Acura do that if it wore down so fast like that? Even so, I am never going to take it off if I keep it on now, so what diff does it make in that regard? Just asking...
woah....old post re-visited. I was the OP on this and I originally took it off for a different look. Plus it was hard to clean underneath that damn thing. I may put it back on next summer, leaving it off for the winter so no snow gets under there, etc....
Once I took it off, there were some grooves from the rubber seal. At first, I washed it and did the whole Zaino thing. Did nothing. HOwever, after a couple of subsequent washes, it looks pretty close to new. I originally had mine on for about 1 year.
Anyway, after a couple of months without it on, the wind noise isn't so bad. I barely notice it, except when using the bluetooth. Bit noisey then.
I like the car without it on, but it does serve a function.
My deflector causes no problems! Least of all whistling...I love it! Did I say that already? Oh well...
