Might purchase 08 TL Type S 6MT, any owners please advise
I might be purchasing a 08 TL type s 6 speed. I have a couple questions, if anyone can please help me out.
How is the fuel economy in the city and highway?
How is the reliability? The one I am looking at purchasing has higher miles at 90k (all highway). Is there any major maintenance due soon for a type s of that mileage?
Is there any problem area I should inspect outside a normal inspection items?
fuel economy in the city, expect 19-21.
highway - as high as 34mpg.
there is a 105k service which includes timing belt and water pump.
Honda MT's have always had a 3rd gear issue.
dating back to early civic si's to s2ks, 3rd gen TL, 4th gen TL, etc.
I recommend draining the MTF and replacing it with GM syncromesh Friction modified.
It cured my 3rd gear pop out.
I have an 08 6mt and here are my thoughts.
Expect to change the tranny fluid as each and every single Type S 6mt I test drove had weird 3rd gear issues and they even popped out of gear. I did the GM fluid change on my 08 and its 100% perfect shifting ever since. So do not let a questionable 3rd gear steer you away from a car you want. The GM fluid will fix it.
Fuel economy is very good and its infact measureably better than the 5at version. I know I have owned both. I get 25 around town in the far chicago suburbs and thats without ever touching a highway. I dont ever really need to drive on the highways so I dont have that number for you. Im sure its 30+ especially since I get 25 without being on the highway.
If you like to get on it a lot get used to no traction whatsoever in 1st gear and a LOT of torque steer in 1st and 2nd. Only time you will get traction is if its a very hot summer day where the tires and pavement are hot. Atleast my 08 with stock tires doesnt get traction.
With that mileage your gonna need to get the timing belt done in the not too distant future. That can be pretty pricey.
My car has been great with the exception of this damn surging issue I have had. I drove other Type S 6mt's that didnt do it, but mainly in 2nd and 3rd gear my car surges during normal acceleration. Check to make sure yours doesnt do that because it drives me nuts and I cant figure out what it is and neither can the dealership.
Lastly, the 6mt takes a LOT of getting used to and is the most tricky manual transmission I have EVER driven. To be honest its pretty annoying sometimes especially 1st gear, but whatever its still fun. Stalling is not the issue its finessing it to make the car somewhat comfortable to drive in. I see my wifes body bouncin all over the place sometimes if I dont get the clutch and gas perfect lol.
Hope this helps.
James
Hope this helps.
James
The following 3 users liked this post by JTS97Z28:
Thanks James!
I agree, my 06 TL was/is the hardest car to learn the clutch.
I have no problem jumping into another car and mastering the clutch in day, but the TL took at least 3 weeks to master.
I, also changed out my tires to a sticky summer tire. I'm glad to report that my torque steer has been reduced.
Thanks James!
Yeah the Michelins will spin all day. Stickier tires help acceleration greatly, you just have to know the torque steer is have a good grip on the wheel.
Desert Life Sucks!!
I say if you can afford to buy it and be able to get the 105k tuneup out of the way then do it.
timing belt job gonna cost around 1400.00 at dealership easy. that includes:
timing belt
water pump
I highly recommend new tensioner - some people don't
check cam seals, crank seals for oil leakage (honda v6's have been the best IMO for not needing new seals 1st 100k miles where 4 cyl are notorious for leaking)
spark plugs - 125.00 a set
change coolant if not already done so and because most will leak out when water pump is changed.
new serpentine belt and power steering belt
Those are the major things and I may be missing some.
If you can do all this work yourself you should be able to do it using genuine Acura parts for about 5 to 6 hundred - just parts.
JTS - sounds like the IACV or similiar could be causing your problem. I had a weird idle stumble but a new air filter took car of that. It still takes a half second longer of key turn to start then any other Honda I have owned.
I notice a little hesitation on half throttle in lower gears but I overcome that with more throttle lol.
I got 29 mpg hwy over a 4 tank average when on vacation. I averaged around 21 city driving overall average is around 24-25
This car gets its sticker fuel economy dead on. If yours doesn't it needs something.
I plan on changing plugs early but I also live at 5200' above sea level. I am a little starved on air as it is.
timing belt
water pump
The only negative the J32/35's tend to have would be is for all that tq-steer down low the engines have, the power is low at the same rpm all that tq happens (idle to 3000rpm) but when vtec x-over happens, the tone change and constant climb in power doesn't end until fuel cut-off. I like a motor with a lot of top-end. Thats why I've only owned Honda products (all VTEC motors) since i was 19yo . I hope I wasn't rambling.
www.colradodetail.com
Absolutely NOT... Torque-steer is exactly that. When you floor any model TL because there is so much power being put through the front wheels that it can uncontrollably yank the steering wheel hard from left to right. If you floor the car while turning left or right the wheel will violently pull harder to the direction you were turning causing to over correct. That is Torque Steer. It's a nascence buts it doesn't take long to learn how to modulate the throttle when pulling out onto the street from a side street or when flooring it going forward at a light. I had no problems because i had a CL-S6 before i became a paraplegic and now my upper body is so strong that after my first car since my spinal-cord injury (08 Honda Accord EX-L/NAVI 4cyl) the 08 TL wasn't much of an adjustment. It def brought back memories of how i managed control of my CL-S6. You'll love the car. I love my 08 non-Type-S but I'm commenting because the power-bands of the J32/35 are exactly the same and peak hp/tq rpm are the same which is a rare occurrence with motor cousins. Nissan's VQ-series V6's don't have these power similarities.
I have an 08 tl and have been a Honda owner.... my DD is a 91 civic lx 4dr with 298560 on it!! i hope to see the same mileage on the TL!!!
Thanks everyone for the replies I am hoping to pick up the car next week if it has not sold.
Thanks,
James
Zonian22
11-14-2015 01:20 PM
IIDXholic
10-08-2015 07:53 AM
Hau_nguyen91
09-06-2015 12:53 PM
