Me vs. 08 M5
I don't know where to begin. I was coming home on the LIE tonight and see a sexy, white M5 with wheels and a huge lip. Looked very good rolling. Anyway, I paced him for some time but didn't think anything would happen. I usually don't pick too many races, but I also don't get an M5 that often @130am.
I toyed with him, dropping it into 3rd and punching it for a second. I did it again at his side and still no response. The 3rd time we both went for it. This was from a semi-high 3rd gear roll. Top of 3rd we were side by side, dead even. Side by side into 4th gear, then mid 4th I started to creep on him :what: Shut it down at the top of 4th where I had about 1/2 car on him. 4 explanations: 1) Viagra....(limp mode) 2) The M5 owner got tired of going fast and swapped the 545 or 550 motor :no: 3) He was in a high gear or toying with me (tho he would've had to toy pretty hard) 4) The AXA Equitable 800lb gorilla was in the trunk I KNOW my car isn't close to the level of an M5 in any way, shape, or form. Idk what to make of it. |
LOL, you my friend, are one HELL of a driver. Who knows what happened..."a win's a win" right? PUHAHAHAH! GOOD KILL! I don't care what the reason is...
Maybe wasn't in M mode? Or whatever adds the extra 100 horses...but STILL 400 hp M5 > most cars on our level, but you SMASHED em' (of car of that caliber and winning by half a car lengths = smashing) |
It's crazy but when it comes to the streets, the drivers count so a win is a win. Today I was driving with my friend and I pulled on a Crystler C300, I got him by a half a car length by 4th gear which then we shut it down. He rolled his window down and yelled out good shit and went his lovely way.
he was gettin road head :boink:
and sonnick took the oppurtunity to smoke him :rofl: |
Originally Posted by alexSU
(Post 11814646)
and sonnick took the oppurtunity to smoke him :rofl: I wouldn't doubt it! |
haha sounds like a blast! I forget which car mag did a run in the M5 in the 400HP mode but it ran a 14.4 in 400HP mode! 500hp mode would have been a different story.
nice kill..im assuming he cant drive and left it in "normal mode" not "m mode" or whatever the hell its called lol
(Post 11814646)
and sonnick took the oppurtunity to smoke him :rofl: IIRC, someone here also had similar results as you. He also pointed out that the M5 without the 500hp mode or M-Mode (i guess?) is a low 14 sec car which would make perfect sense. |
14 second car with 400 hp? goddamn that thing must be heavy. what year?
Originally Posted by phee
(Post 11815523)
Originally Posted by ineedmyfixofacura
(Post 11815686)
According to title it was an 08. I think they started coming out with the latest GEN M5 in 2004 or 2005? The older ones had 400hp no more.
It weighs about 4k so even in p400 it shouldn't be a 14second car but idk...he was probably just screwing with you, because in P-500 (M-mode) an smg III equipped M5 is a low 12 second car. Our cars are more a match for an E34 M5(2 gens before).
^^ spot on.
Originally Posted by AtlM5
(Post 11816811)
Originally Posted by jeowen
(Post 11818481)
Def, I understand your excitement man, but c'mon bro- I know your smarter than this. Its an M5---------an M5.
Originally Posted by Sonnick
(Post 11818576)
I know man! In my post I said clearly I'm no on an M5s level, but it was fun. I doubt the M5 is a 14 second car even with 400hp. I made it sound like 400hp isnt a lot lol. I love racing faster cars, even if they're playing around!
http://www.insideline.com/cadillac/c...-benz-c63.html Acceleration comments In default mode (P400, D3) this car is "slow" off the line, shifts lazily, and reaches 60 mph 1.5 seconds later compared to max-attack (P500S, M6) mode. With these M settings, the launch is an unpredictable orchestra of mash-throttle/rev/clutch-drop/tire-spin/lift/mash-again that's very difficult to replicate more than a couple times at best. One run of six felt correct and representative of the M5's true ability. Very harsh upshifts are quick enough to break the tires free, and the shifts are quick enough to keep up with the tachometer -- never missed a shift. P500 mode Performance 0 - 30 (sec.) 2.3 0 - 45 (sec.) 3.6 0 - 60 (sec.) 4.8 0 - 75 (sec.) 6.6 1/4 mile (sec. @ mph) 12.8 @ 115.1 Now add 1.5 seconds to the 0-60MPH and you get 6.3 seconds to 60MPH which my Auto Accord V6 could pull off haha! Now I know 4.8 seconds isn't the fastest to 60MPH that we have seen the M5 go in P500 mode but it definantly gives a perscpective on the difference between the two modes. |
(Post 11816811)
i think it should switch to p500 mode when you floor it
(Post 11818829)
(Post 11818860)
Ehh, I think it's pretty bad ass when you press a button and your car gains 100hp, I'd rather press a button then it doing itself.
doesn't an 08 M5 comes in V10 500HP???
Originally Posted by DIZAZNDOOD320
(Post 11819065)
I don't know guys, I just like buttons ok... it's a fetish!!!! |
(Post 11818576)
^lol
Maybe from a dig the 400hp mode of the M5 runs low 14s, but from a roll it still has to be quicker than a 14 second car. Either way it was fun. And damn is that car sexy :what:
i still can't get over the fact that a 400HP M5 is a low 14's car....thats crazy! why would they make such a huge gap in performance between the 400hp mode and 500hp mode
(Post 11819726)
maybe if the M5 has a Dinan chipped then it wouldn't be running low 14's
Features & Specs
http://cache.bmwusa.com/image_831e9b...68ffb74ea.arox Weight Unladen 4012 lb Weight distribution, front/rear 52.2/47.8 % Engine Liters/cylinders/valves per cylinder 5.0/V-10/4 Displacement 4999 cu cm Bore/Stroke 3.62/2.96 in Nominal output hp/rpm 500/7750 Max. torque lb-ft/rpm 383/6100 Compression ratio 12.0 :1 Transmission 7-speed SMG gear ratios – I/II/III 3.99/2.65/1.81 :1 7-speed SMG gear ratios – IV/V/VI 1.39/1.16/1.00 :1 7-speed SMG gear ratios – VII/R 0.83/3.99 :1 7-speed SMG gear ratios – Final drive ratio 3.62 :1 6-speed manual gear ratios – I/II/III 4.06/2.40/1.58 :1 6-speed manual gear ratios – IV/V/VI/R 1.19/1.00/0.87/3.68 :1 6-speed manual gear ratios – Final drive ratio 3.62 :1 Performance Drag coefficient 0.31 Cd Top speed1 155 mph Acceleration 0 – 60 mph2 4.5 sec Fuel consumption 7-speed SMG transmission – City/Highway 3 11/17 mpg 6-speed manual transmission – City/Highway 3 11/17 mpg Tires and Wheels Tire dimensions (performance tires) – front4 255/40ZR-19 Tire dimensions (performance tires) – rear4 285/35ZR-19 Wheel dimensions, front/rear 19 x 8.5 / 19 x 9.5 Material light cast alloy Brakes Front – diameter 14.7 inch Rear – diameter 14.6 inch for a 4.6 sec 0-60 mph how can it be running 14's ??? |
(Post 11819955)
Features & Specs
ohh didn't know they had a P500 mode like that a friend of mine has a M6 and i driven it seems to be very fast! but i didn't see that mode
Let me get my cam in and then see how I do against it in P500 mode.. I would say that once I'm maken about 410 to 415whp it will be close. That would put me around 465 to 480bhp...
327 whp in a 4k car. there we have it guys
^^ Definitely makes sense now. Still has to be quick with that much power, even if it weighs 4,000lbs. I was reading on the Bimmer forums a couple ran an M5 in their e46 M3 and had similar results I did. Either it was really close or they inched it out.
OBVIOUSLY he wasn't in P500 mode, he would've wiped me all over the street. I kinda wish we ran again with him in P500 :yum: |
Originally Posted by F23A4
(Post 11821607)
From European Car magazine: With two factory power modes available (P400 and P500), we tested both to see the difference. It turned out to be well more than a 100-hp difference after all. Additionally, the P400 mode gives more of a typical V8-like curve, with all its peak torque at the beginning, and falling off up top. More akin to a racecar with wild cams, Sport mode, on the other hand, ramps up torque for a huge power surge by 6000 rpm.
With a 445 whp baseline, this BMW is nothing short of a rocketship. At 327 whp in the P400 default mode, however, a lot is left on the table should you forget to press the "M" button on the steering wheel. Here's a notable comparision of an E60 M5 P400 vs 650i from M5board. |
So it wasn't really an M5 when I raced it...more like a S/C TL rolling 3 deep! Lol.
If I'm not mistaken, the P400 is for comfortability and it helps save gas similar to the M3 and some current cars.
gimme a m5 ill rn in p500 mode all day~!
