Making Audi Style Eye-Lid
04 TL - CAR_PC
1 Post
I don't know this post will fit to electronics section but since there is all electronics parts are involved I will post here.
I have 04 TL W/O Navi (I Installed Car-PC) and try to install FOG Lamp but It looks too boring so why not make a audi style eye-lid which looks cool.
I have all the parts ready and making eye lid that can be install into fog lamp grill.
I am using 9X1watts creed style white led per side generated brighter than audi and look very cool.
Only hardest part was that LED generate a lots of heat. For that reason, I used aluminum plate 3/16" thick that can be used as heatsink and hold LED.
You could also use 1/2 watt strawhead style LED (lot less heat generation and easy to install than 1 Watts Version - I will try this another time).
I try to make detailed photo but too lazy to make that photo.
Anyway, It will be finish soon.
Once I finish I will post picture how it look.
I thought the same that LEDs dont generate that much heat, but my interior LEDs get extremely hot when they are on.
Where are you putting these LEDs? Are they going into the headlights where the HIDs are....because the HIDs do get pretty hot. I dont quite understand the thread OP....I read it 4 times and still lost...lol.
one of the biggest issues Audi has had in goin with the LED lights has been getting rid of the heat. Regular LED lights do not generate much but, but heat is still bad for them.
04 TL - CAR_PC
1 Post
I ran test for whole week(left it power on)and I relized 1 watt LEDs are too hot(it goes to 160 degree - this will reduce when the car is moving) and cannot feed thicker wire to indivisual LED.
So, I failed.
I try other method that using 1/2Watt Straw Head LED.
Advantage of using that LEDs are generate less heat, no need lots of wire to feed LEDs and easy to make water resistance.
Disadvantage is less brighter but still compatible or brighter than AUDI LEDs.
As soon as I make em I will post it here again.
So, I failed.
Some miscellaneous info:
Audi uses VERY high efficiency LEDs in their headlights/LED strips. These are very expensive bulbs. To match them bulb-for-bulb you would need ~5W LEDs which would give off a TON of heat with several used.
Also, you need to check your LEDs in the daylight, from a good distance away. It's easy to look at the LED's from 10-20 feet and in a dark room and think "that's bright enough." Plus, most LED's are not diffused and 80%+ of the light comes straight out... whereas Audi's LED's can be seen from a decent angle.
I think you'll find it tougher than you think (though not impossible) to create a home-made system to match. I just suggest not trying to cheap out on the LEDs themselves if you want a comparable design.
Best bet would be to get a hold of the Audi LED trip and figure out a way to integrate it properly. Might not be the cheapest or easiest way, but would definitely be the best result.
Hope that helped.
Hope that helped.
04 TL - CAR_PC
1 Post
Hope that helped.
Hope that helped.
well, thanks for your advise and I will go for straw head LED either 1 watt or 1/2 watt.
If it's emitting light, it's emitting heat unless it's a chemiluminescent reaction. So unless you want to capture a bunch of fireflies and stick 'em in your headlights, you're gonna emit heat
04 TL - CAR_PC
1 Post
You are welcome and have a fun with it.
If you could use 1/4" Aluminum bar will cool down led to 100 degree which safe for LED(up to 160 degree).
I use 2 X 39Ohm 50watts resistor(that has heatsink buit in one per each side connect all 9 led will eliminate ugly wire hanging back of plate - only 2 wire).
Make sure correct value of Resistors are needed for proper operation.
I will post picture once I finished.
Just don't get side-tracked by a straight Watt-to-Watt comparison... it's the lumens that you need to compare.
Also, I thought that Audi had diffused LEDs since they can still easily be seen at an angle... but if I am incorrect (and they are focused), you would need to do the same to match their brightness (or of course use more powerful diffused LED's).
Good luck though, hope it turns out well.
04 TL - CAR_PC
1 Post
Well it does sound like you have a decent idea what you're doing. But like I said, keep in mind Audi uses high-efficiency LEDs. They're running ~100 lumens/Watt (I think it's slightly less) for their LEDs. Whereas the ones you're using are probably ~50-60 lumens/Watt. Lower efficiency, thus probably less light and more heat.
Making AUDI Style Eye-Lid for TL not for AUDI nor copy itself.
Mine show 70Lum/Watt that is bright enough(Check on daylight) and no need to match exactly same as audi uses.
Getting an idea is different than making copy.
I just want it to share the idea that might interest some people in TL community.
I can do the math 15, 25, 30, 45, 60Degree lens angle and reflector makes different beam pattern.
I will not expect 100% satisfy in virgin try but so far I like way it is... (SInce I found the solution of heating issue)
thanks for your concern.
04 TL - CAR_PC
1 Post
Finally, I test fitment to my TL today and I found way brighter than AUDI.
Here is the photos (sorry for poor quality - cell camera) you could see much clear than acutal photo show and you can also see from 140 degree.
I am very happy that works great.
Q('.')=O
Props to what you have done but honestly, IN MY OPINION, they are too bright. I mean, just look at the pics from the front, ( I dunno if it is photo distortion or whatever, or if it is the alcohol) but all I see is a giant light aka can't see the individual led's. If it were not as bright it would look more legit and more .
04 TL - CAR_PC
1 Post
Imagine the audi led's and mine slightly brighter than audi.
Currently, I am working on circuit that connect to daylight and turn signal.
LED remain on during drive but once turn signal given each direction side led will flash(I think kind of cool).
I am making circuit for it.
Once it finish then final installation will be made and that time I try make more photo(use digital camera) and post it here.
Looks nice!
Waiting for the sexy clear pictures.
VERY NICE LEDS....you planning to make more just to sell it? if you do let me know! I'll buy it!
i think i've seen you drive around. Are you around the san gabriel area often?
if so, the LEDs that you've installed is very bright, too bright imo.
The car i saw that looked exactly like yours had the LEDs on at night and it overpowered the headlights making it stand out wayyy too much.
looks nice, but dim it down to match the headlights and i think it would look much better
Wow you make that look surprisingly easy.
If it was just a semi-bright light and not actually used to make the night look as if it was daytime, then it would look really really nice. Artistic almost
04 TL - CAR_PC
1 Post
Photo shows very bright but it is only camera's reflection.
I could see very clear and you could control brightness by ajustable resistor or higher resistor (for my opinion cureent setup will be fine).
As I told it slightly brighter than audi's.
04 TL - CAR_PC
1 Post
I will be installing this comming sunday.... post will be soon.
What LED does.
1. Reamin on all the time work like day light.
2. LED flash if directional signal given (left, right or both-if hazard button pressed)
I'm hoping clear picture post by sunday.
What LED does.
04 TL - CAR_PC
1 Post
True, That is reason why I used aluminum plate as heatsink.
I turned on for 5 hours without any air flow that aluminum plate heatsink shows 140 degree which is fair but with airflow (car is running) it goes down to 90 degree which is better than I expected.
Average life span for LED with above tempreture will be 10000 hours.
LED can be replaceable if it goes bad.
