Maintenance Service ...Input help
Hello acurazine..... I just got a 07 type s with a lil under 77k
and im wondering what full service should do to the car... timing belt adjuster timing belt tensioner timing belt timing belt idler water pump serpentine belt air filter cabin filter Transmission 3rd and 4th gear 91213-rkg-003 x 3 28600-rke-004 x2 28610-rke-004 x1 is there anything im missing.....Or do you guy's recommend anything else that should be done.... Thanks |
the timing belt is due at 105k miles, you're only at 77k...you should wait.
you should absolutely change out ALL fluids. this includes; -transmission -brake -engine oil --coolant -power steering fluid def. change out the pressure switches. That's basically it for a car with 77k miles...as there's not much to do. |
(Post 15241285)
you should absolutely change out ALL fluids. this includes; -transmission -brake -engine oil --coolant -power steering fluid def. change out the pressure switches. That's basically it for a car with 77k miles...as there's not much to do. thanks for the input:thumbsup: |
inspect brakes. if pads or rotors are needed, change them out!
