Lower Control Arms
Vegas Bum
Lower Control Arms
Does anyone know where to find the best deal on front LCA's for a 2006 TL?
I usually get aftermarket parts from Rockauto but for some reason they do not have LCA's available...they have them for other Acura's so I am wondering why they don't offer them for this car.
Thanks in advance!
Thanks in advance!
I would check the closest import salvage yard. New OEM LCAs are not cheap; I would buy used ones and have a shop press in new bushings. You'll have to decide if the price difference is worth it.
Vegas Bum
I bent my subframe last winter sliding into a curb of a round-about @ 20km/hr in some black ice so I had the subframe straightened out and I replaced my UCA when it happened which made the car pretty solid until recently...now the FR inboard joint is leaking grease and there is a rotational hum around 100km/hr, not to mention that the camber is slightly out of spec on that side. I figure that if I am going to do the Axle, I may as well do the LCA at the same time...I may look into getting the left LCA bushings pressed in if I am going to end up spending $300 per arm.
joflewbyu2
10-08-2015 11:16 AM
