Lost Gas Mileage?
Old 01-15-2009, 09:49 PM
rahulkumar's Avatar
Lost Gas Mileage?
For some reason, my MPG has dropped from roughly 21-22 to 18-19. Worthy changes are mainly a new set of tires. The temperature has also dropped slightly to about 40. Furthermore, my car was recently stuck in the mud with no visible damage to the undercarriage, but if there's anything that might be affected I thought it'd be worth mentioning. Any ideas?
Old 01-16-2009, 12:58 AM
marmaladedad's Avatar
1. Winter gas
2. Are you basing your mpg-numbers off the number of miles traveled divided by the number of gallons put in, or by using the MID?
Old 01-16-2009, 09:58 AM
cotmfk's Avatar
I've heard tires can make a difference if:
1. they are heavier than the old ones
2. they are wider than the old ones (ie: went from 235 to 245)
Old 01-16-2009, 12:39 PM
LoveMyTL-S's Avatar
Mine seems worse also. Seems I'm hitting the gas station more. I have been driving more with family visiting but still. Is the winter gas that much of a diffence?
Old 01-16-2009, 02:34 PM
darksky's Avatar
Right... do NOT use the numbers the MID is reporting to you. Calculate your mileage yourself: fill your tank until the gas pump stops. I can squeeze an additional 0.25 gal or so before it's full. Reset a trip odometer. Drive the car until your near empty, then refill to the approx. same level (i.e. until it stops, then add the same amount you did, 0.25 in my case). Now divide the miles as per the trip odometer by the gallons.
Here are a few factors that will affect mileage, there are probably more:
-Errors due to incorrect tire size (i.e. now your odometer is counting too fast)
-Outside temp (colder being worse)
-Winter/summer gas formulations (winter being worse)
-Weather (rain, snow, etc.)
-Driving style (fast starts, high speeds, etc.)
-Cruising speed (you'll get better mileage at 65 than you will at 80)
-Traffic density (frequent slow down/acceleration)
-Head/tail winds
-Tire rolling resistance (performance tires are worse in general since they are made to be 'sticky' and provide you with traction. A/S tires can also hurt mileage, but hey, you bought them for their saftey and grip didn't you?
-Inflation (under inflated = worse)
Old 01-16-2009, 02:49 PM
200,000 mile club
mmade22's Avatar
Cold weather = Bad gas milage
08KBP_VA
10-22-2019 01:55 PM
xsilverhawkx
10-05-2015 11:00 AM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
San Yasin
09-29-2015 10:52 AM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: Lost Gas Mileage?
