Looking for lock for rear seat
Hi guys, this weekend I tended to the task of running 1a 2v line and remote turn on for my sub amp. Which involves removing the side panels and the rear seat.
One of the things I did was break that plastic lock piece that locks the seat back into place.
I'm not sure what its proper term is but, I noticed after the fact, its lever you pull out slightly to allow you to life the seat up.
Im searching acuraoemparts but without a diagram im screwed!
Bubz, I know the feeling. I wasnt able to remove the seat at first. So I assumed, like my accord you just pull up firmly and it pops off a clip. Little did I know this one has a lever.
Thank you Trew..
Thank you Trew..
No problem.
Also, when removing you should push down on the seat while pulling the clip out. this helps it release from the clip cleaner, without obstruction from the lever.
And for the seat back, don't remove the bolts all the way. Turn them about 6 full turns and stop. Then push up on the seat back and pull away. It "hangs" on the bolt like a picture frame on a wall. This helps equally as much when putting it back on.
rockyboy
08-04-2024 10:35 AM
