LED turn signal switchbacks questions
WARNING, LONG POST WITH MANY MANY QUESTIONS
Ok so I'm planning on clearing my headlights this weekend and I'm going to replace the stock turn signal bulbs with LEDs. the problem is, I have no idea which ones to get. I am currently looking at the switchbacks on http://www.autolumination.com/switchback.html but which exact ones do I get? is it the 7443 bulb with 48 or 60 LEDs? And what is the difference between Amber-White (AO) and Amber-White (AW)? which one should i get if I want it to run white but signal orange? and also I'm told i'll need load resistors so i'm look at some from http://autolumination.com/equalizers.htm and which one of these am I supposed to get based on OHM and Wattage? I'm sorry this is such a long post but I really don't want to mess up and do it over again. Thanks in advance |
Originally Posted by Xpecial
(Post 13661130)
Ok so I'm planning on clearing my headlights this weekend and I'm going to replace the stock turn signal bulbs with LEDs. the problem is, I have no idea which ones to get. I am currently looking at the switchbacks on http://www.autolumination.com/switchback.html but which exact ones do I get? is it the 7443 bulb with 48 or 60 LEDs? And what is the difference between Amber-White (AO) and Amber-White (AW)? which one should i get if I want it to run white but signal orange? and also I'm told i'll need load resistors so i'm look at some from http://autolumination.com/equalizers.htm and which one of these am I supposed to get based on OHM and Wattage? I'm sorry this is such a long post but I really don't want to mess up and do it over again. Thanks in advance It doesn't matter if you get 48 LED, 60 LED, 68 LED, or even 120 LED. They all fit. The more LEDs = The brighter the light output. (I highly recommend you get at least 60 LEDs because it's kind of hard to see 48 LEDs during the day time with the sun shining on your head lights. Other cars will not be able to see your turn signals until they are very close to your car, compared to being able to see it from 100+ feet away. At night time LEDs look bright as hell no matter how many LEDs you get) The difference between AO and AW is... AO (Amber-Off)- When you turn your headlights on (or just parking lights with no head lights) than it will light up WHITE. As soon as you hit your turn signal the WHITE WILL TURN OFF and it will blink AMBER... AMBER... AMBER... AMBER... Once you complete the turn, or turn off the turn signal than it will turn off amber and go back to WHITE. WHEN YOU DON'T HAVE ANY LIGHTS ON AND SIGNAL, IT WILL JUST BLINK AMBER...AMBER..AMBER...AMBER... AW (Amber-White)- When you turn your headlights on (or just parking lights with no headlights) than it will light up WHITE... THE DIFFERENCE HERE IS as soon as you hit your turn signal it will blink AMBER...WHITE....AMBER...WHITE...AMBER...WHITE... Once you complete the turn, or turn off the turn signal it will go back to WHITE. WHEN YOU DON'T HAVE ANY LIGHTS ON AND SIGNAL, IT WILL JUST BLINK AMBER...AMBER..AMBER...AMBER... Here is an example of my car with AO Here is an example of CLtotheTL32 switchbacks with AW (Amber-White) And for your question about the resistor. I highly recommend you just to do this. It's easier, cheaper, and more safe. https://acurazine.com/forums/3g-tl-2004-2008-93/g-109-diy-eliminate-led-bulb-induced-hyper-flashing-without-load-resistors-815219/ |
Wow I did not expect one single person to answer ALL my questions. Thanks a lot man you deserve a medal. So I think i'll go with the 60-60 SMT Stealth ultimate switchbacks from the website i mention. Can i just stick them into the headlights or would i have to retro fit them?
^ great answer. Helped me out too
(Post 13661590)
Make sure you clear your headlights before you do this because if you still have the amber diffuser in place, the WHITE on the LED will still look amber/yellow because of the amber diffuser. AMBER DIFFUSER + White LED = PISS YELLOW. I used to have mines like that until I got it cleared. The good things about those 60-60 switchbacks from autolumination is that they are a total of 60 LEDs that are dual function. Meaning 60 LEDs will light up white, and those exact same 60 LEDs have the ability to change from white to amber, so you get both 60 WHITE and 60 AMBER LEDs. Here's a warning though, some members have had a bad experience purchasing from autolumination and said that they will never purchase anything from them, while other members have had 0 problems. It's up to you... You're risking $70, so if you have the money than go for it. If not, I would recommend eBay instead. Most other switchbacks that are 60 LED are only 30 white and 30 amber (totals 60, but half of the LEDs are 1 color, the other half is the 2nd color). Pay attention to the pricing on autolumination... The price you see is PER BULB, not PER PAIR. If I recall, the price is about $29.99 / PER. You will need two. 2 bulbs + shipping will put you at about $60-70 I believe. I went the cheaper route and just bought 60 LED from Kaixen Motors on eBay. They are 30 white, 30 amber just like you see in my video with the black TL |
oh shoot... looks like autolumination has a pretty bad history. Looks like i'll resort to some other place then. I'll check out the kaixens on eBay, thanks again viet.
i will be purchasing switchbacks in the near future...
no experience with autolumination, and would prefer not to buy LEDs on eBay, i have had great experience with VLEDS http://www.v-leds.com/ |
Originally Posted by 09tbss_rjw
(Post 13662126)
no experience with autolumination, and would prefer not to buy LEDs on eBay, i have had great experience with VLEDS http://www.v-leds.com/ I'd rather get the 60LED from eBay for the same price as v-leds. However, for license plate lights or interior led lights I recommend V-LEDs all the way. Just not for switchbacks |
I was going to go with the vleds but i think i need something brighter. but all the 60-60s on ebay don't really specify If they are AO or AW and I kind of want an AW. also i'm not sure if the prices are per pair or per bulb. anyone else have any reliable recommendations for switchbacks?
-edit- I also heard that 60-60 LEDs won't fit in the housing for our cars. is this true? |
(Post 13664399)
-edit- I also heard that 60-60 LEDs won't fit in the housing for our cars. is this true? You'll probably notice that they are dated from 2007-2009. The reason I say this is because several years ago LEDs were much thicker and bigger than they are now. The technology for LEDs have advances and therefore the switchback LEDs now use much smaller bulbs compared to several years ago, and yet they are still much brighter. They will fit 100%. There's people that have 120 LED bulbs in their TL.. 60-60 LED bulb is only 60LEDs total. |
Originally Posted by vietxquangstah
(Post 13666854)
http://desmond.imageshack.us/Himg856...jpg&res=medium I love em. |
does anyone have any recommendations that have good reliability for 60-60 or higher LEDs? or should I just go with autolumination/eBay
(Post 13667121)
Ebay has 120 LED switchbacks (40 white 80 amber) but they cost ~$50/pair. Ebay also has 60 LED (30 white 30 amber) for ~$30-40/pair. I use these. Sold by Kaixen Motors. These are Amber-Off (Which is also called "Type 2 style" If you want it to blink amber-white than those are also called "Type 1". Some Ebay listings DO have Type 1s, you just have to thoroughly read the listing to find out. |
(Post 13666922)
Originally Posted by VicTL06
(Post 13667449)
Where from? Autolumonation?
I would not buy from Autolumination....their shit doesnt work half the time....
i believe the 1157 bulbs has the heavy duty from Autolumination which works good but the 7443 doesnt have that option....when i ordered the 60-60 LEDS from autolumination the first one arrived dead....had to pay for return shipping....the 2nd one lasted for 1 week and then the same expenses.... i finally got pissed and asked for my money back....when you pay $30 PER LED module + shipping....you expect them to last.... check with superbrightleds or vleds for their switchbacks..... :2cents: |
Mine are the heavy duty version =)
NOTE: I had to specially specify to "Send the heavy duty version". BIG thanks to bforbrian who mentioned it. You have specify it to them, otherwise you'll just buy the regular version. |
^^^ do they have the HD version in the 7443 ??? i thought that was only for 1157....
Do the 120-120 switchbacks fit perfectly into the stock housings?
Originally Posted by swoosh
(Post 13667783)
So yes :thumbsup: I emailed them before I ordered: HI- Please paste this note in the notes section along with your order and we will sent the beefier ones: "Please send heavy duty style per Chris" Chris Bacon |
(Post 13667784)
(Post 13667796)
Mine is a heavy duty version, and it's a 7443 :dunno:
So yes :thumbsup: I emailed them before I ordered: if this doesnt work imma be PISSSSEEDDDD !!! |
(Post 13667857)
can you post a link of what exact product you ordered....i might give them another shot :shrug:
if this doesnt work imma be PISSSSEEDDDD !!! 120 High Powered Wide Angle SMT LEDS Amber |
^^^ ahhh see those are not switchbacks right !!!
(Post 13668888)
^^^ :annoyed:
(Post 13667796)
So yes :thumbsup: I emailed them before I ordered: got a video of these in action? |
scroll up.....VIET has 2 videos posted !!!
(Post 13671150)
I am looking for the 120 all white LED bulb from autolumination in action that guitarplayer16 is using, parking light and blinking... i can't decide if I should get switchbacks or not... |
Don't get white... Get AMBER colored LEDs. Guitarplayer has amber colored 120LEDs.
^^^ i agree....
also i dont think blinking WHITE is even legal....it has to be a different color than the headlights so it can "grab" attention....well not that all mods on my car are legal but just wanted to put it out there.... |
(Post 13671481)
my previous cars both had white blinkers up front, never had issues, i know it may not be illegal but that's not my biggest concern...i didn't know he had amber...my bad. |
Finally got to clearing my headlights and got the 120 LED switchbacks in. Was a PITA but worth it. thanks for answering all my questions guys, but I have one more. I'm looking for a nice super white/blueish HID bulb to color match the LEDs... any suggestions? I'm currently checking out stuff from theretrofitsource and they seem to have a lot of cool things
pure white 4300k
blue/white-6k |
I love switchbacks.
quick question: do i have to open up my headlights to put my switchbacks in? or its just plug and play like replacing my drl bulbs? thanks gurus!
:nono: @ opening headlight
:nod: @ plug and play from the wheel well :thumbsup: |
The difference between AO and AW is... AO (Amber-Off)- When you turn your headlights on (or just parking lights with no head lights) than it will light up WHITE. As soon as you hit your turn signal the WHITE WILL TURN OFF and it will blink AMBER... AMBER... AMBER... AMBER... Once you complete the turn, or turn off the turn signal than it will turn off amber and go back to WHITE. WHEN YOU DON'T HAVE ANY LIGHTS ON AND SIGNAL, IT WILL JUST BLINK AMBER...AMBER..AMBER...AMBER... AW (Amber-White)- When you turn your headlights on (or just parking lights with no headlights) than it will light up WHITE... THE DIFFERENCE HERE IS as soon as you hit your turn signal it will blink AMBER...WHITE....AMBER...WHITE...AMBER...WHITE... Once you complete the turn, or turn off the turn signal it will go back to WHITE. WHEN YOU DON'T HAVE ANY LIGHTS ON AND SIGNAL, IT WILL JUST BLINK AMBER...AMBER..AMBER...AMBER... Awesome explanation! Thank you for also clearing that up for me.:thumbsup: Just want to make sure about one thing tho.. I don't think I saw this answered here or just missed it but would I need any type of resistor for the switchbacks? |
Hi TripleLex. Unless you want hyper flash turn signals, you will need to install resistors OR do the recommended relay mod found here:
https://acurazine.com/forums/showthread.php?t=815219 It was slightly intimidating, but actually fairly simple, even to someone who had never held a soldering iron. |
About the size, I would NOT say they all fit, sir...
My 120's were pushing the limit, if they had been a half MM thicker (that's what she said...) they would NOT have fit into the hole. |
