LED drl's and HID fogs
Hi guys-
My 2007 TL Type-S has the bi-xenon headlights which os nice because it also makes the DRL's more of a custom look rather then have to be funtional for lighting purposes. My question is if anyone has tried the 9005 LED bulb that v-leds sells? Also, has anyone tried installing a HID kit for the factory fog housings? Just curious of the possibility of doing it with mounting the ballast,etc down in the front wheel well.
What are your thoughts?
Thanks!
-Jaysen
Thanks!
-Jaysen
I have LED DRL's. V-LED is currently working on a harness for our DRL's similar to what you'd use for an HID retrofit kit with a relay and direct wire to the battery for full power and it will use resistors to correct the issue with a DRL light. If you're interested in making this harness yourself, PM me, but I'd recomend just waiting until V-LED's comes out with theirs. This will provide the LED's with a full 12V of power instead of the current 6.6V or whatever it is.
Hi guys-
Thanks!
-Jaysen
Thanks!
-Jaysen
i currently have 5k LEDs in my fogs as 06' base doesnt come with DRL but rewired them to look like DRL can switch on and off, but they look awsome at night with switchbacks and during day from far look like low hid 5k bulbs.
