Learning to drive a stick on brand new 2006 TL
#42
Originally Posted by sandynmike
Let us know how it went!!
Mike
Mike
#43
Mike's Silver Bullet
Both are correct.
Thinking about it as holding the clutch, then adding a little gas, etc, makes it easier to learn, since you only have to think about one foot at a time.
It's really all about coordinating the clutch and the gas so the rpms stay around 1000 or so until the clutch is released. Doing both at the same time works too.
Mike
Mike
#44
Both are correct.
Mike
Mike
#45
Registered Member
Originally Posted by ninor
thank you! one stop light around my school campus where i was learning to drive is at decline and my car stalled twice when i tried getting it started in 1st. do i just apply more gas or what?
#46
Registered Member
hey! starting it without giving it any gas and then giving it some gas when the rpms start dropping was fairly easy to me but then they started telling me to press the gas pedal at the same rate as i am releasing the clutch and i had few good starts at that and jerked it few times. which way is the proper way?
#47
I Skydive, Therefore I Am
Originally Posted by Southernboy
Item #5. I disagree with "NEVER... EVER... downshift to slow the car". What I would agree with is if the operator does this from speed (or skips shifts on the downshift), it is not a good habit. I suspect you and I pretty much do the same thing.. let the car slow down naturally (if possible), the just slip it into neutral and use the brakes. Where people go wrong with downshifting to slow down is doing this in too low a gear/to high engine RPMs in the lower gear.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Most of the time when I ride with someone we come up to a corner they down shift the nose drops, then rises again as they hit the gas. THIS IS IDIOCY and what I'm really trying to warn against. Over time it really wears on everything from the tires, CV joints, transmission, clutch and even the engine (the journal bearings are being shocked in all kinds of directions and that isn't good.)
Someone mentioned a light flywheel as being a reason why you can't get the TL started without the gas and a lack of torque, sorry but the thread has become too long for me to quickly quote you, my apologies.
My reply is this; the second car I ever took on an autocross track was a 1985 Toyota Corolla GT-S with the 4A-GE 4cyl out of the MR-2. The 4A-GE was so high strung that it makes the TL's engine look like a diesel as far as torque output goes.
Originally Posted by Ninor
i'm glad to see you all posting here and helping me out, i really appreciate it! today and tomorrow are going to be big days for me in the terms of learning how to drive my car. my moms boyfriend is taking me to some parking lots today and my friend who has a 2004 TL is taking me there later on today. I will mostly try using techniques from first 3 posts on this page (southernboy, sandynmike, and 6mtrules) and see how that goes. my moms boyfriend has been teaching me to hold the gas around 1-1.5k rpm and then start slowly releasing clutch and press more on gas when rpms start dropping. my main problem has been is that when i start pressing on gas i usually start releasing clutch faster as i do not have the "motion" of "weighting balance" with my feet. i will post when i come back from driving with my moms boyfriend and let u know how the new techniques have been working for me!
The "secret" to driving a manual is to find the engagement point of the clutch. If you practice starting out without the gas you will quickly learn where that point is and then you can start feeding the gas to get your starts much quicker. Take your time and PRACTICE, that is the only thing that will get you comfortable.
As far as how I learned how to drive a manual, my older brother taught me on his 83 (I think) Ford Escort, then I drove a Dodge pickup (slant 6, how many of you remember those), then a friend's dad taught me how to drive his Willys with a non-synchro'd transmission. If you think a manual TL is hard to master, just try to drive a non-synchro'd transmission, but after a while RPM matching and double clutching becomes second nature, I got to where I could shift it with my pinky finger. The more advanced techniques I learned from various professional driving courses. I've attended 4 over the last 20 years.
CanopyFlyer
#48
The DVD-A Script Guy
For a while I think there where a bunch of members that thought the VSA could be working against you if you get into a jerking (or "bucking") mode and cause more jerking. I tried it and didn't notice any real difference but then again I've been driving MTs for a long time.,
Could be BS or could help. I dunno. I just figured I'd share what I heard.
Keep practicing, you'll get there.
#49
Registered Member
Originally Posted by CanopyFlyer
I disagree with slipping the car in neutral, but not strongly, although with an automatic it is an absolute no, no. I like to keep the engine in gear until I'm just about to come to a stop, but before the engine starts to drag against the brakes. I will downshift as the speed falls off, just so that if I have to accelerate the drivetrain will be ready for it, but at no time does the engine take up braking duties. There is only one set of brakes on a car. ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
As for starting off at some given RPM, I advise this for normal conditions (as in not having to get moving quickly). Engage the clutch as quickly as possible with as few RPMs as possible, and do this as smoothly as possible. This all sounds mutually exclusive, but it isn't. When I say engage the clutch as quickly as possible, of course I'm not talking about banging the clutch out. What I am saying is do not slip (ride) the clutch for 5/6/10 car lengths before full engagement takes place. However, in order to engage a clutch quickly (again, normal conditions), your engine has to be turning rather slowly because if it is not, you will need to slip the clutch a bit before the wheel speed catches up to the engine speed. Lastly, you must strive to do this smoothly, which means no jerking and no stalling. Under normal driving condtions, I tend to use around 1000 RPM to launch from a stop. This will vary depending upon conditions of course. Sometimes, it is as low as 800 RPM, though not too often. And sometimes if I have to suddenly accelerate quickly, it's around 1500 RPM.
Anyway, it looks like you and I are pretty much on the same page with all of this.
#50
Originally Posted by SouthernBoy
Perhaps I wasn't clear in my statement about slipping the car into neutral. I do pretty much the same thing as you do. As the RPMs drop close to idle, my speed would also be slow so I just move the shifter to neutral at that point. I never go into neutral at any kind of speed because I want to have control through the drive train as much as possible.
Ninor, you are getting some very good advice in this thread. The problem will be how you interpret it.
If you remember anything, remember this, anytime your foot is on the clutch pedal you are causing expensive wear to your car. The trick is to use that pedal as little, as quickly and as smoothly as you can possible do it.
Oh one other thing point that I have not seen on this thread.
THE CLUTCH IS NOT A G$K D@#N FOOT REST. Keep your bloody clodhoppers off of it till you need to use it.
CanopyFlyer
#51
Having been in your shoes a year ago with my 06 TL, I want to add that this is all great information. However, be careful not to overthink all of this...at some point for me it was better to "just do it" and everything flowed. The more I thought about the rpms and car-lengths I was slipping the clutch, the more the car jerked and the higher the launch rpms. The less I think about it, the smoother everything goes and the less wear on my car. This info can create a great foundation. In the end, just breathe, take your eyes off the tach and just go.
My
Good luck!
My
Good luck!
#52
Registered Member
My
Good luck!
My
Good luck!
So perhaps it is really a good thing that he gets a lot of this up front so it will serve as a good grounding for his development. Anyway, I'm sure he'll do just fine.
#53
Complete and utter agreement. Looks like you and I went to the same school of driving.
CanopyFlyer
CanopyFlyer
once again thank you guys and i am reading this thread over and over while pretending i'm driving a car right here at my desk
