Just hit 50k miles. maintenance needed?
So i just hit 50k miles on my 2005 TL and i was wondering what maintenance do i need to do. I know i need new tires and change the brakes for sure but what else should i do at the same time while my cars in the shop?
thanks
thanks
have you though about looking up all that info inthe owner manual?
its right there and depends on how you drive as to what schedule to follow
Dont have the book??- here it is free- click year then model
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
I just passed 50k as well and need service soon. My car says it needs a B1 service which is the following:
- Change oil and filter
- Rotate tires
- Inspect front and rear brakes
- Check parking brake adjustments
- Inpect the following: tie rod ends, steering gear box and boots, suspension components, driveshaft boots, brake hose and lines (including ABS), all fluid levels, exhaust system, fuel lines and connections.
- Rotate tires
brake fluid starting at 3 years, then every year forever
ps fluid 3 years wont hurt to do it!
coolant 5 years- or at 105k service with new water pump
trans- many discussion on 3 qt partial change or 9 qt- known as 3x3 method
Acura has lowered the interval on the new cars but it doesnt solve the trans problem
In the owner book- link above- there is a complete listing of each service and then you see if normal or severe use is how you drive~
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
nanos
11-12-2015 08:41 PM
