Just got back from track..and im pissed.
So I just got back from Sac Raceway Park, kind of disappointed.
The only mods I changed since the last time I ran was lowering the car.
I thought I would run better times since I would squat less off the line.
My First run was slightly better 60 foot then last time, but I was slower up top.
I ran my numbers through a density calculator, and came up with a time that was actually .05 faster than the last time I went, so I guess that was why, but it sure hurt to a slower time.
Best on may 5th:
Reaction: .56
60 ft: 2.304
330' 6.303
1/8th 9.571
MPH 75.902
1000' 12.4
1/4 mi 14.781
MPH 97.554
Best Today:
Reaction: .229
60 ft: 2.28
330' NO DATA
1/8th 9.709
MPH 76.684
1000' 12.561
1/4 mi 14.96
MPH 96.313
I only got in 3 runs, I forgot I had to wear long pants so I ran to costco and bought a pair of cheap jeans real quick so i missed out on about 3-4 runs, then after i got knocked out of bracket racing I left since my GF wanted to leave.
Best on may 5th:
Reaction: .56
60 ft: 2.304
330' 6.303
1/8th 9.571
MPH 75.902
1000' 12.4
1/4 mi 14.781
MPH 97.554
Best Today:
Reaction: .229
60 ft: 2.28
330' NO DATA
1/8th 9.709
MPH 76.684
1000' 12.561
1/4 mi 14.96
MPH 96.313
04Tl
And ur runs arent too badd your are a second gen? right? type-s or base? and yea ur second time around was prolly due to different weather. but at least u got a better 60'. Good luck next time.
2003 Accord Coupe V6
I am really suprised at your time. Your best today you had a 2.28 60ft and an 1/8th mile time and MPH of 9.709 and 76.684. Your 60ft and 1/8mile MPH were much better than your previous best run but your 1/8th mile time was slower? That makes no sense. You lost about 2MPH between your 1/8th mph and 1/4 mph this time vs last time. Something doesn't make sense. I can see why your dissapointed haha. You might have to go back again when you bring your pants!
Same track, it was about 15 degrees warmer this time
03 TL-S, Last time at track, CAI and Cat back exhaust,this time only difference was that I am lowered in addition to those mods.
Also, I think my 60 ft was better because I loaded up a torque converter a bit to see if it would help with my times, Maybe my top end suffered from a worse DA, also only getting in 3 runs coudl have played a part, it was only my 2nd time ever to the track and maybe my shifting from 1-2 and from 2-D3 werent at the right times, as compared to last time I went.
I am in nor cal, so the next time the weather is nice I am going to try to get out again
What do I check for? I know its a INtake Manifold Control Runner, but what does it do and what am I looking for?
I thought it was maybe the weather?
When VTEC kicks in,it's obvious, plus ive felt relatively fast on the street.
Ok, if i touch the spring on my IMRC it feels loose, but the butterfly opens and closes smoothly, cable feels tight not but not super tight, i can wiggle it MAYBE 1/16 of an inch
opening the throttle triggers the IMRC, and it closes after RPMs drop
I took off the IM cover( i think thats what it is) and the right side looks very caked with carbon. I cleaned it out as best as I could without using any form of cleaner, I don't knwo if it safe to use any cleaner fluid?
The cover part I took off was also dirty on the same side, cleaned out best I could.
LIST/RAMEN/WING MAHSTA 짱
But, to answer your question: Sea Foam.
IMRC was working fine, took off the IM and cleaned out the EGR port alone with the mani itself, broke traction shifting into second while I was in D5 and the engine was already warmed up ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Can't wait to go back to track.
rockyboy
08-04-2024 10:35 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
