Installing Transmission Temp Gauge help on Accord
hi guys, i've found a couple Threads via Search but was wondering if you could help me install a Trans Temp Gauge on 7th Gen. Accord V6
any thoughts where i could put a T Adapter?
i can't for the life of me find a definitive answer on this...this is what the V6 ATF Filter + ATF Warmer looks like
Welcome to Acurazine.
Might I suggest the Accord forums for your question?
you can most likely get that data via the OBD2 port if that parameter is reported in the data stream, most relatively newer cars do report that temp.
