Important info for all TL owners (my story inside)
#41
Originally Posted by PeterUbers
Well, I guarantee that I did not see this light.
How much damage could be done w/ my just running on 2.5 quarts of oil? When he took the oil filter out (the Amoco mechanic) there was oil in the filter, and a bunch of oil drained into a pan that he placed under the filter. Then, when he installed the new filter (as seen in the pic) he only had to add 2.5 quarts to the engine . .. when I came home, I added another 3/4 of a quart.
I wouldn't bring my car back to them for service in the future. The service department obviously doens't know what they're doing.
#42
Hmm, you think they would have thought of that being a problem. I guess they assume you wont be getting that much travel on your control arms under sain driving conditions. Good to know, if we hit a pothole ill make sure its checkd. But first...To get the car.
#43
WDP Director of R & D
If the light never came on then you probably never starved the oil pump for oil. Whether you have 1 qt or 5 qts in the pan, if the pump never experienced cavitation, "oiling" within the engine would be normal. The main difference is how hot the oil would get. The main reason stock vehicles as well as race cars have certain "volumes / reservoirs" of oil pans is to ensure #1 that the oil pump is never starved due to "drain back" restrictions/oil movement within the engine, and then an amount of oil to achieve proper cooling and time between oil changes etc..
Given your description it's obvious the oil filter had a few "pin" holes etc. allowing oil to leak out under pressure. As long as the filter was not restricting oil from reaching the block/bearings you are good. Most engine oil pressure sending units are located after the filter galley thus the light should of come on if the filter had significantly restricted flow. In all reality if you do the math,,,,, if the Amoco guy installed a new filter and added 2.5 qts to full, like you mentioned - you were “only” 2.5 qts low. The 3/4 qt you added at home was what the filter/lines filled with. The old filter/lines had oil in it thus one can't say you need to add that to the amount "low"...
Either way, your engine is probably fine. Due to the fact that you drove the car for ~two months after hitting the pothole the filter was obviously leaking slowly – most likely very slow to begin with and more so in the last week or so. Thus, your oil level probably exceeded 4 qts for quite some time and then dropped below that amount more rapidly towards the end. Overall, the time spent at or below 3 qts etc. may very well been a short period of time.. Only you know how hard you pushed the car during those two months but if you never “starved” the oil pump,,, (and I know it’s easy for me to say) no harm was done to your engine.
Just my and analysis of your engine/issue. Must have been a hell-of-a pothole…
Ouch!
Best of luck - Cheers
#46
... I'll know in 10,000 miles or sooner if i decide i want the dealer to investigate the inner components of the engine.
I'd keep an eye on the oil level and check it every week. If you start to notice increased oil consumption you may have sustained some internal engine damage. Once again, the way to find out for sure is to have the engine opened up and inspected, which is why I was so concerned in the first place by your mechanic just changing the filter and adding oil.
#47
Regarding the dealership, have you checked your receipt to see if the p/n of the oil filter is listed? Even if it isn't, you may find that the dealership is using the wrong size filter on all TL's and will acknowledge it. Hopefully, no damage has occurred and this will all be a non-issue. However, getting the dealer to agree to the facts now would make it easier to get them to cover the costs involved if you were to have problems at a later time.
#48
never stops!
Nice post Peter. Hope there is no engine damage. Before you changed oil, did you observe the the diff. as in how much oil had lost due to cracking this filter before you refilled it? We might do some guestimates on how low the oil needs to go before the light comes on.
#50
For PeterUbers,
Does your oil light extinguish quickly upon starting etc.? One way to tell if you have excessive bearing wear or oil pump issues etc. is by how long it takes for an engine to build oil pressure. If the light goes out instantaneously upon starting with no "flickering", all is most likely normal.
Good luck
#51
Outta my way!!
Originally Posted by DocTL
If you figure that an oil filter holds roughly .5 quart, he added 2.5, and you .75, you were about 3.75-4 quarts low. That is low enough to cause damage to the engine, but not as severe as running the engine without oil. The only way to determine if there was damage is to 1) inspect as I previously mentioned, or 2) just wait and see if you develop any problems in 10,000+ miles.
Now let me speculate. One detail was overlooked here: when mechanic removed oil filter, he might had lost another quart of oil easily. Which means there was about 1.5 quart of oil shortage
my 0.02
mugen_kid
11-13-2015 10:38 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
asahrts
09-04-2015 05:55 PM
