I'm at 55k what services should I be doing
Only thing I've done to my car is oil change and tire rotations, air filter and cabin filter.
I'm getting new tires today, and I've got a B12 service showing as well.
Other than the regular maintenance items I've done above, what should I be looking to do?
AZ Community Team
Received 7,771 Likes
There was thread on non-standard maint items that someone started, but I can't find it via search. I thought it was in Problems & Fixes; it was fairly current.
Maybe someone else can find the link.
There is not much to be done until you reach 60-80,000 miles. I would flush the brake fluid the next time you change the brakes and change the Manual transmission fluid. On Automatic transmissions you have to change it every 30,000 miles this is very important. and around 80-100,000 mile change the spark plugs and flush the radiator. Acura recommends changng the spark plugs at about 105,000 but I would not wait that long, I changed mine at 85,000 miles on my TL and I saw a difference in gas mileage and better performance. also at 105,000 you should change the Timing belt, water pump and do a general inspection of the entire vehicle. I hope this helps.
