I need a new headlight set up...Recommendations are welcome
B A N N E D
Alright so my ballast took a crap, I want to buy a new hid kit, suggestions?
I also want to run a DRL set up using HID's any suggestions on that?
Thanks in advance guys...
Land of 10,000 lakes
Cheaper isn't always better when it comes to your HID components. You can contact Matt at The Retrofit Source and see if he has any OEM TL ballasts.
I have a set of Matsushita gen 4 ballasts sitting around somewhere I believe if you're looking for an OEM. I'm sure it won't fit in the spot where our OEM one sits because they have an octagon like shape.
Phmbm12
DDM is pretty reliable IMO. sort of. i got two sets. for the fogs and the oem. but i didnt get a ballast for the oem so they go out. but the fogs work great! lol
Rev High; Drive Happy
Your fogs operate at 100% versus if you install DRLs itw ill cut the power to around 50% thus the color and intensity of a HID will be lowered.
If you plan to strictly keep it DRL then you might as well get a Nokya or Hoen yellow bulb. If you plan to still keep the upper fog then you can go HIDs.
IF you have 07/08 headlights you will run the risk of melting the shroud/bezel with a HID.
darn i see thanks, weird how both my lights flicker so hard to test whats going to die ahha so I guess ill search ebay if anyone know any other site for some oem ballast would be great thanks.
braveheart
09-07-2015 08:12 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
