I need help
I need help
I’m gonna try to make this a through as possible but a month ago my oil pressure light came on I got the car home and have not driven it since I changed the oil pressure sensor when I did change it no oil came out where the sensor screws in in my personal opinion I believe that indicates that the oil pumps not working since no oil pressure I’m just not sure what I do change the oil pump or put a new engine in the car everything else about the car is perfect it does have 240,000 miles
A silly question: What does the oil level indicate on the oil dipstick?
Latent car nut
Received 2,007 Likes
Unless you took the oil pressure sensor out while the engine was running (definitely a bad idea), then I wouldn't be alarmed about no oil coming out.
Tyrone503 (02-18-2021)
wardak33
10-27-2015 08:06 PM
