i know another oil question...sorry help needed now
Sorry first oil change comming up....do you have to take it to the dealership? or could i just take it to jiffy lube....what kind of oil do you guys use!! I need to know soon because i want to do this today becaues i'm leaving this weekend for a trip! thanks guys
change it yourself or go to the dealership. I have had bad experiences at those "quick-lube" places...
Changing the oil is pretty easy. Just jack up the front and remove the passanger front tire and you there you go you have easy access to your oil filter.
I went to a strauss auto near where I live to do my oil change. I provided them with oil and filter. Cost me $15 though. I used Pennzoil Platinum 5W-20 full synthetic with a mobil 110 filter.
Go to any local shop, bring your own filter and oil...
Which oil? You said that you've searched? Yeah.. Right... Mobil 1 Extended, Royal Purple and/or Amsoil.. peace. |
Buy the filter and oil and bring it too a shop if you don't know how to do it yourself (though you should learn sometime when you have the car). I am starting to put Penzoil Synthetic just because Walmart has a amazing deal on them and almost all synthetic are same.
castrol edge too....great oil... im using it now and the car is running like a champ
It's nice changing your own oil and all but I saw some scumbags in Queens who did this and dumped the used oil into the sewer. :whyme:
Wouldn't it be simpler to go to a lube shop, have them change the oil (10-20 minutes) and pay 20 bucks instead of crawling under your car, draining the oil into a drip pan, and refilling the used quart containers with the old oil, and transport the used oil to your nearest lube shop to recylce said oil. No? It would be understandable if it cost 200 bucks to change the oil. :2cents: |
I think the first service should on a brand new car should be done at the dealer-
just so they have a chance to look underneath and make sure everything is ok with your new car. They also run the VIN and see if any recall fixes have popped up for it Gen 3 has PS issues~ From then on do your own changes, or the neighbor kid taking auto shop in school,,anyone but a quick lube- whose techs dont care about drain plug crush washers and torque specs on the bolt. Can destroy an oil pan,, and the engine in worst case scenario!!! |
^^ spend $8 on a oil pan that closes up and any autozone will take it for free.. i usually do my changed right at the store.. 20 minutes and im out.
Some of us have a relationship with the car that goes beyond sitting behind the wheel.
Working on the car yourself is a sense of pride and knowing it was done right. You check the CV boots and look for road damage or fluid leaks. No one else is going to do that. A few minutes to drop off the old oil at any parts store is simple part of the test drive after. test drive after an oil change? yep- any reason to go for a buzz in the TL! |
zone often has a package deal with drain pan, oil/filter, hand cleaner.rags, etc uder $25
please dont work on your car in the parts store parking lot
IF you should drop any oil in the process it gets washed into the main water drains and into the environment...bad news for fish and other living things Most stores have a sign saying not to work on cars there...sure in an emergency but an oil change??? dont you have a home? |
Originally Posted by CarrieLynn
(Post 10570396)
Originally Posted by 01tl4tl
(Post 10570783)
Originally Posted by luckyAKAhappy
(Post 10570751)
Wouldn't it be simpler to go to a lube shop, have them change the oil (10-20 minutes) and pay 20 bucks instead of crawling under your car, draining the oil into a drip pan, and refilling the used quart containers with the old oil, and transport the used oil to your nearest lube shop to recylce said oil. No? It would be understandable if it cost 200 bucks to change the oil. :2cents: 2nd they dont let the oil fully drain out 3rd they use some random oil that comes out of a unmarked barrel via a pump. 4th they don't clean the bottom of the car from the extra oil, in fact they do you a solid favor and relube the entire underside because their hands are covered in oil 5th they leave your car running first and only time there i took my friends beater cause he needed an oil change, it was jiffy lube and that is what they did^ |
Originally Posted by Tripnbeats
(Post 10570515)
"You check the CV boots and look for road damage or fluid leaks. No one else is going to do that."
I beg to differ.... all shops love oil changes. Although they make very little money on the oil change itself, their goal is to have your car on the lift to they can provide a free inspection and "find problems" so that they can make money off the repairs. |
If you like your TL, don't take it to a quick lube place.
I had to go to one of those places one time on the girlfriend's Murano because I was taking it on a 500 mile trip and didn't have time to change it. I brought my $10/quart Amsoil and $14 filter to them. I thought everything was fine until the next oil change came up. I got under there and there was the same Mobil One filter I had put on the time before. I went back to square it up with the mechanic who did the change (I remembered him because he was some gangbanger looking fag that kept staring at me) but he had been fired supposedly. If you have to pay someone, pay the dealer. They are less likely to screw it up and if they do you have a better chance of them making it right. |
ive taken my car to the dealership in the first six times since i bought the car with me providing the oil. but now that my friend has a shop, i did my recent one there. bought an oil filter from Acura along with the crush washer, five 1-qt bottles of Mobil 1 0W-20 and did the oil change.
saved around 15 bucks vs bringing it to the dealer even when using my own oil. |
Originally Posted by Majofo
(Post 10571074)
I'm waiting to try it out.. that stuff is expensive.
It's all marketing hype, guys. No better than Mobil One. |
I know some people that work at these shops and I wouldn't let them check the air in my tires. Stay away!
Originally Posted by I hate cars
(Post 10571318)
LOL. This has been discussed a lot over at bobistheoilguy. What we know for sure right now is it is not a full synthetic. Whether it's grp III or grp III and IV, we don't know.
(Post 10571335)
Good to know.. I actually heard word of mouth.. I'm sticking to RP & M1, (whichever I get a better deal on at the time). Glad you closed the case on this one for me.
LOL. You guys are waaayyy to paranoid about going to a lube shop or are extremely unlucky. But all your tales are funny though.
Originally Posted by RC51Ryder
(Post 10570875)
I actually had a tech at a quick lube joint remove one of my spark plugs because I had military plates on my car and he was kicked out of the military. I guess he decided to get back at "The Man" by making my 4 cyl run like crap. At another one across town, the "convicts" changing oil liked my car so much, they got my home address from the computer and came to my apartment to steal the CD player and subwoofer out my car. Needless to say, I do my own oil changes.
you're right it is a marketing hype.... but when i put it in my car and going over from mobil 1....it made a difference and it feels alive now.
(Post 10573721)
I would have went back there and beat that guys ass!!!!
When my car was broken into, I couldn't prove it was the knuckleheads at the lube shop so the police wouldn't do anything. Of course, I knew they did it because of the way they were eying my car when it was in the bay and it wasn't even 24 hours after I got my oil changed when it happened. I didn't go back there because had I did, with my temper, I would have shot one of the kids and been in jail over it. No thanks. Keep the sub and the changer but it will come back on them sooner or later. |
^ Yeah, there is a bunch of losers that work there! My friend Jeff goes to WM to get his oil changed in his TL and I yell at him about it all the time! He's kinda strange anyway tho...
(Post 10573709)
