I hit 38k miles today what's next?
B A N N E D
What should i do as i approach 40k? i bought it at 29k back in may 08' as a certified preowned car, i dont know about any recalls on it or anything so what should i do?
YAH! its that cold in orlando today!
GO DAWGS!! SICK'EM!!
you can do whatever you want to your baby....40k...probably just oil change, change filters, maybe a drain and refill on the transmission fluid, rotate and balance tires, etc. or complete 3x3 process on the transmission fluid...
good luck
good luck
at 38K there isn't really anything to do if the maintainance has been done on time. Do you know if the cabin filter was changed? Engine air filter? If not, we can meet up some time, get the fogs done and I can check and change the filters and show you how to do it, its pretty easy to do, a philips scewdriver and a jacket. BTW, 35 degrees here at 6 AM.
Inspired
srry to hijack the thread r u sure we have to do 3X3 process cause i asked the tech at my local dealer and he said just once
The once is for just drain where the car will let out 3 qt of transmission fluid and you refill it backup the 3qt.
3X3 method is the correct method to change out the transmission fluid completely where drain 3 qt then warm up the car, then refill. then repeat this process 2 more time hence 3x3 method. Your ACURA dealership should know about this. Here is a thread about it.
https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
Good luck
One on the right for me
B A N N E D
AndrewS
19
03-14-2024 06:59 PM
