Hpde
Hpde
Who does DD and HPDE here? Would you recommend a base TL or TL-S? Base TL would be modded with wheels, tires, brakes, suspension and bolt ons.
I know the base TL weighs close to 3500 Lbs, is that a hindrance or power makes up for it?
I wanted to like the 04-08 TSX but found it to be underpowered for almost 3300 lbs.
Thanks.
Thanks.
You're looking for a daily drivable sedan at the price point of a TSX, that's reliable and robust enough to track, and is not underwhelmingly slow?
Well...it doesn't exist.
Fast sedans cost $$$$ and will kill you with maintenance. Some may say that an EVO or STi is a fast sedan within reasonable cost. But let me point out that both those cars are absolute shitboxes. And that "within reasonable cost" would need to be applied in a very flexible way.
I don't think you'll have better luck with a TL as compared to a TSX.
There aren't any winners or losers in HPDE. So really, a successful HPDE platform is something that has a reasonable consumable cost, good reliability, and is reasonably competent at turning/braking. Tons of slow cars are HPDE heroes.
The TL will have a higher consumable cost than a TSX...and it's fatter, longer build will make for more car to need to throw around.
A TSX is about the size of a 2006-2011 Civic. It's a bit heavier than the civic because it has a double wishbone suspension and some luxury aspect to it. It's a good chassis, however...and the engine has tons of potential. A Euro R LSD trans would add massive amounts of potential.
If you want something more raw, have you considered a 08-11 Civic Si sedan?
There have been quite a few success stories with CL7/9 HPDE builds. It's got a lot of great starting points. What did you feel it lacked? What exactly was unsatisfactory about the TSX? How many times did you track it, and did you spend much time on setup or tuning?
I have a 05 Si (suspension, brakes , tires and wheels) that I track currently. The TSX felt much heavier (it is) and lethargic to change directions when compared to it. I did not drive the TSX at the track, just some spirited drive on canyon roads to understand its capability. I think what you are saying is right, getting a right mix of secondary (revised) DD and some HPDE days may not exist due to compromises needed on each end.
A friend of mine, Bret, races a 3G Tl in autocross and SCCA events and does really well. He calls it his "race whip". Here's a story about his car: The YAWSPORT TL - Bret Norgaard's Race Whip - apexjunky.com
Maybe you can get some ideas from the race whip. His company is Yawsport and he's located outside of San Diego. I'm sure he could build you an amazing car if your serious. Good luck.
Thanks.
Thanks.
